S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Ipod
Old Nov 16, 2004 | 11:20 AM
neilbaud's Avatar
Question Ipod
Hi guys, I have a 94 S500 and I'm thinking about adding an Ipod to my current strereo, has this been done to the MB factory radio? I have a CD changer now with the 10 pin connector (not optical) I don't care about loosing the CD-Changer in lieu of the IPOD, any suggestion?
Thanks, Neil
Old Nov 19, 2004 | 12:54 AM
MEINBNZ's Avatar
96' S420
Thumbs up iTrip
They make a product for the iPod called iTrip that uses the FM frequency on your car radio. What you do is plug in the iTrip adapter into the ear plug adapter on the iPod and then you find a static frequency on your radio. Lock in that static station to a preset on your radio and the turn on the iPod and there you go. It costs about $30 for iTrip and you don't have to mess around with your CD player. Here is the website. I hope that helps.
Corey
http://www.griffintechnology.com/products/itrip/
Old Nov 23, 2004 | 07:55 AM
neilbaud's Avatar
Post Ipod
I was thinking about the Itrip, but you loose on sound quality, and if you live in the New York Metro area, forget it, signal interference is a killer, but here's what I've found, check the link out.
http://frontiernet.net/~dbipes/SLK/m...pter/index.htm
This will work better.
Thanks for the update.
Neil
