S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Problem with brakes
Old Dec 16, 2024 | 12:20 PM
Lars535's Avatar
Problem with brakes
I have an w140 280 and have problem with the bakes. I swaped the brakelines and 2 calipters and after that the pedal got soft. I am able to pump up presure but when i hold it, it slowly goes to the floor. I have tried swaping out the main cylinder and it didnt help. Any suggestions?
Old Dec 16, 2024 | 02:09 PM
sprucegoose's Avatar
03 SL500, 07 S550, 92 500SEL
I had the same symptoms with a bad ABS/ASR module. replaced with a working unit from CA. Pedal and brakes are now restored. This presented itself after brake work as well. 92 500SEL.
Old Dec 16, 2024 | 02:26 PM
Lars535's Avatar
Thanks for the tip. I will try replacing that. Hav any idea why it happens?
