S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Trouble going into reverse
Old Jan 27, 2005 | 09:32 AM
mojobenz's Avatar
93 500 SEL
I haven't had any transmission issues until now, and it was recently serviced by a dealer. When cold, my 93 500 SEL slips into reverse fairly easy. Once it warms up, for the past few days, it's having trouble. I know the dealer will want to put in another tranny, but this one works smoothly otherwise. Anybody have any ideas about what's causing the problem? A band? Electronic control unit somewhere?
Old Jan 28, 2005 | 10:15 AM
mojobenz's Avatar
93 500 SEL
I've lined up an appointment with an independent who specializes in Euro cars. He said it can be repaired without replacing the tranny. I know the dealer would say replacement is the only option. Will keep this thread updated for the benefit of others.
Old Jan 28, 2005 | 07:59 PM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
I was told by my local Independent mechanic to get it in ASAP if I have problems getting it into reverse, or if I hear a clicking noise while I am backing up. Otherwise, replacement is the only option. Apparently this symptom indicates a slippage of components inside the tranny that will eventually lead to the tranny digesting itself. This relates to the units used on the 140 chassis.
Old Jan 29, 2005 | 06:32 PM
irons500's Avatar
My 92 500 sel has began to develop the same problem. When the car is put in reverse, I hear a clucking noise. Any idea how much the cost of the repair may be?
thanks
Old Jan 29, 2005 | 07:25 PM
mojobenz's Avatar
93 500 SEL
I have an appointment with the mechanic on Wednesday morning. He said it would take about two hours to check it. Then, I'll get the good news, bad news report. It's a hydraulic transmission and could be the vacuum, bands, or whatever, but he suspects its fixable...he sounded familiar with the problem.
Old Jan 29, 2005 | 10:16 PM
dlafever's Avatar
No idea on the cost of the fix, only that it is cheaper to fix it now, than it would be later. A rebuild by a reputable shop in Phoenix is about $1,600.00, just for reference.
Old Feb 2, 2005 | 05:06 PM
mojobenz's Avatar
93 500 SEL
Problem solved
Mechanic put it on his machine, said pressure plate bad and something about an O ring. Since he has to take things apart to fix it anyway, he suggested a rebuild for $2K. Sounded reasonable, so we're doing it.
