Transmission not shifiting well COLD
1995 S320 and 1995 S500
When I first start my car, the transmission seems to shift well (into its second gear) but after warming it runs smooth and gentle. Any suggestions?
1995 S320
Gman
1995 S320
Gman
try synthetic transmission fluid such as Redline ATF-D4 transmission fluid, its probably the best ATF out there, Royal purple is also very good. It is smoother in all conditions and is much more fluid like in colder conditions / startup.
1 Post
2018 GLS63 AMG
It is common with the W140 5 speed to have a long hard shift from 1-2 from what I have read. There is not harm in changing the fluid, it mayl help relieve some of your worries and smooth out the cold shifting
even the 4 speed does too. fluid will make a substantial difference b/c normal tranny fluid is like molasis so it doesn't flow nearly as well as a high performance synthetic like Redline ATF - D4. just thought i'd mention that.
