S430 stuck in park
S430 stuck in park
Start the car after work, no problem, try to put it in gear the shifter is jammed in park
Anyone experience the same problem or have a clue to what might be wrong
2002 S430
Thanks, Ron
2002 S430
Thanks, Ron
S320L (W220)
turn the ignition key to position two, make sure the fans and comand are turned off so there is no noise. Slowly increase pressure on the brake pedal, you should here a noise from the gear shift lever. If you dont, it just means the safety catch has becomed jammed, hopefully shouldnt be too expensive to fixed
My 2001 S500 got stuck in park, so I looked at this forum for suggestions as I always do. There were no answers other than call roadside assistance and let them hammer the shifter out of park and take it to the dealer to have it repaired. The price tag was high and my curiousity got the best of me. As it always does, so I again looked at my WIS program for help in fixing the problem. There was no real help other than how to remove the shifter box.
So...I removed the shifter box. This entailed removing the center console to get to the shifter box. I had to also unattach the linkage under the car to get the shifter box out of the car.
Once out, I proceeded to unassemble the shifter box.
What I discover was amazing. There is a small plastic part ( I estimate about 10 cents in quantity) that is responsible for allowing the shifter to be taken out of park. It is activated by a solenoid that pushes the plastic part to allow the shifter to come out of park. Most of the parts in the box were metal. This particular part is plastic and very frail. Obviously a victum of very poor engineering. It is easy to see that this part will become stressed over time and fail.
My concern is that we are all good MBZ owners and take our cars to the dealer for repair most of the time. This is certainly not a DIY normal job, but my curiousity got the best of me.
The part can be replaced ( I think) although the pin that allows the part to move is pressed into the housing of the shifter box. I was not able to press it out, as space was very restrictive. The way it was engineered I suspect MBZ never intended to replace this part. In my estimation, this is certainly a candidate for a recall. Obviously when you take your car to MBZ for repair, they replace the whole box and never tell you actually what was wrong. I read that one person paid $1,300.00 for this repair. A little high for a 10 cent part that is a very poor excuse for this kind of use.
I know what you are thinking. Maybe the other shifter boxes had something else wrong with them. Could be true. However, in looking over the entire box, not much could go wrong. The design is very simple and very low tech. If you want more information post your concerns.
I am going to contact MBZ about this problem to see what their response is. Nobody should have to pay for this problem. It is definitly an MBZ problem. Not your normal wear and tear.
Oh BTW, I removed the remainder of the broken part so I could use the car while researching this problem. Everything works fine, the only thing is that you do not have to step on the brake to take the car out of park now. Operates like the old cars before steering and park lock outs.
PICTURES AND MORE DETAILS https://mbworld.org/forums/s-class-w...k-problem.html
2005 S500 4-Matic, 1978 450SL
Welcome to the forum, Ray, and thanks for a quality post. It's the kind of informative post we love to see.
The post to which you linked is one of the better ones on this topic, and as you can see, some folks have tackled it as a DIY. There is also a vendor selling metal replacements.
When you have something as informative as this, you might in the future open a new thread, rather than appending it to an old one.
I don't mean to diminish your contribution or your efforts - Thanks, and please keep them up!
stuck in park
Thanks for the help on this problem. I was able to remove the cheap broken plastic piece in the shifter mechanism and save myself over $1000. Took a bit of research, but this forum was a great help!
Stuck in Park
Yesterday, it took me three hours to get that little piece of plastic out of the gear shift. Well, most of my time was spent with the center console, but still I saved well over 1300.00 doing it myself.
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
My SL55 had a similar problem when under warranty. Roadside assistance came out and replaced a fuse in the trunk, and voila!! No more problem.
