Nitrogen on Tires
I am a Fire Protection contractor and we use N for a supervisory gas and for testing in our high end systems as opposed to air because of it's stability.
Tire pressure has always been an important part of automotive performance and in high end applications Nitrogen is a better choice. Now, finding it becomes another issue.
Air isn't free at a lot of gas stations up here. SoBs charge $.50 to run the compressor for 3 minutes. Sux even more when the hose is too short to get all 4 tires in one shot.
Damn, I hate that!
The N fillup will probably last as long as regular air but when you need to add a few lbs, you need to go back to the N dealer. Adding compressed air will defeat the purpose. No known side effects.
I have read that in racing applications and in military as well as commercial civilian aircraft that it's used regularly, mainly due to it's temperature stability.
I have a couple of Nitrogen cylinders that I keep at my shop for testing....maybe I should put a regulator on them and sell this stuff out the back door. Let's see, I think each one holds about 1800 cu ft at 3000 psi so at $3~$ a tire..... the profit margin would be tremendous!!!
BTW, how is N a larger molecule than O or CO2? It's atomic radius is the smallest of the 3 though not by much compared to O. However, O is not normally found alone in the wild so O2 is much bigger. Or am I not seeing something here?
Here's also a link i found that might help.
http://www.whynitrofill.com/vsoxygen.htm
By the way, there's this thing I want to sell you called the Tornado - gives you about 20 more horses!
