Smart or stupid?
BMW E39
Smart or stupid?
It's a cheap method for sure.
Basically, my airbox gets really hot after drives. I'm thinking about coating parts of the tube and airbox with aluminum foil. I believe that reflects heat and does it pretty well? Maybe cool some of that hot air the engine is sucking in. What do you think?
![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
not simple foil, but insulating foil, right? though there is part of my brain
which thinks the benefits are small...though better than none at all.
may be more rewards in locating the point of induction to cooler air
source as well?
source as well?
BMW E39
Next time you think of that...go out and get laid...you'll get more out of it.
source as well?
source as well?
I wouldn't waste my time with something like that. Testing theories on a top model Benz...not the best way to go.
88 Caddy on 28's
You might try some of that heat insulating material that they sell in speed shops. You could get the smallest sheet that they sell and cut it up and cver the box...I think you might do better by finding a way to direct more cool air to the underhood area.
Dad - '04 ML350E
if you can afford an s-class benz, i think you can afford some sort of coating at a shop or something?? instead of some tin foil..lol
just a thought
just a thought
