s500 front brake rotors
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
i was trying to change the brakes and rotors on my 2000 s500. i unscrewed the bolt that holds the rotor to the hub but i cant break the rotor free. how do you guys pull off the rotor?
thanks
angel
thanks
angel
Did you take off the calipers already? If not the disk does not come off. If yes you need to use force. Best is a rubber or plastic hammer to beat from the back of the disks while turning them. If this does not work you may need to heat them up carefully with a torch.
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Bamberger is right - if you have some penetrant oil or WD-40 I would liberally spray at the seam and let it sit for at least 15-30 minutes and then tap w/mallet as Bamberger described. Just ensure that you thoroughly clean afterwards though!
ok. thanks for the advise. i will be doing that. i actually used a dead blow plastic mallet and it didnt work. i then used a small 2 lb sledge and all it did was chip the ends. lucky for me, thats all it did because after i couldnt get it off, i had to put it back together and drive it.
angel
angel
im doing a whole brake job. new ceramic pads and brembo rotors. that is why i wass trying to pull off the rotor. its been raining so i havent had a chance to do anything yet. my garage is full of other cars so i cant do it in there and out of the elements. i think we had something like 26 days of rain here in san francisco which is supposedly a new record. anyway, i will get to working on the s500 when it stops. in the mean time, i will be working on my camaros in the garage.
angel
angel
