transmission
Old Apr 28, 2006 | 10:51 PM
lorinserSclass's Avatar
S 430
transmission
Does anyone know where to get the A/T dipstick tool to see if there is enough fluid when I do the filter change...Can't find any website that has it in stock..thanks
Old Apr 28, 2006 | 11:05 PM
S 430
found it on good old Ebay!!
Old Apr 29, 2006 | 06:08 AM
lloyds's Avatar
2004 CL500
If the part number of the transmission dip stick is 140 15 21 00 you will find that it is to long and you will need part number 140 589 49 63 00 which is an extension pipe used when filling the transmission.
Old May 1, 2006 | 02:24 PM
S 430
When I looked up some DIY websites..they say that the tool is suppose to stick out about 8 to 10 inches above the engine..they say that is normal..what part are you talking about...are you referring to when I add new transmission fluid?..thanks
Old May 5, 2006 | 04:12 PM
lloyds's Avatar
2004 CL500
mercedes make an extension pipe to add to the filler pipe which then makes the dipstick the correct length
