Steering or suspension creaking...omgggz annoying
Old Jul 16, 2006 | 07:07 PM
midget fidger's Avatar
E550 Coupe
Over the last year or so, the 00 S430 has been making this horrible creaking noise. It comes and goes so whenever we get around to taking it to the shop, the problem goes away. We took it in around March and they did some stuff to fix it, but now the problem is back again! You mostly notice it at a standstill or at low speeds - turn the steering wheel left and right and it will moan. You can even feel it on the steering wheel itself. If you hit the button to raise the car, it'll creak. If the car is raised and you shut it off, it'll creak as it lowers itself. It's pretty stupid when you're driving a nice car, go to park it or reverse out of a parking spot, and the damn thing creaks like some rusty POS.
Is it a common problem? Please help me (and the dealer) figure out what's wrong with it
Old Jul 16, 2006 | 10:03 PM
midnight's Avatar
2004 S500 2005 Crossfire SRT-6
I have a 00 S500 and experienced the same problem. I originally thought it may have been the brakes because squeaking appears when I began to stop or just start to move. This annoyed the me as well. Just like you mine would come and go and when I found the problem I realized why it would. I took it into the dealer and they told me I needed to replace the entire front suspension system, from shock absorbers, ball joints, control arms, bushings $4.5k was the quote. I took it to an independent shop and located the real problem was with the rubber boot cracking which is near the ball joint. The fix was to replace the ball joints and boots on both sides I also replaced the control arms which was needed. For about leass than 1K. The the noise on mine was coming from the rubber boots. The reason the sound comes and goes I noticed when i drove the car in rain or over puddles the sound would go away for a couple days to weeks and then when those boots dried out again the noise came back. AS a quick fix just to make sure thats the problem. WHich is what I did before the work was performed. I sprayed a good 'ole WD40 on the boots on both sides and drove the car for about 3 mile and the sound went away until I took it in to get repaired. These boots are just behind the wheel right above your control arms. Try that first to see if this is the problem.
Old Jul 16, 2006 | 11:45 PM
E550 Coupe
Thanks! I'll get someone to check out that part and post back here
Old Feb 9, 2009 | 01:33 AM
phirama's Avatar
w140 & w220
yupe I know for sure your problem was just a ball joint.. I just replaced mine few days ago both of them.. after making super bad noise.. but make sure tho to change your tierod too while replacing the ball joints ...
Old Feb 10, 2009 | 01:03 AM
S5LorinserF1's Avatar
2003 Mercedes S500 Lorinser
its the ball joints. i had the same problem on my car. The only problem is you have to replace the entire lower control arms which can be alittle expensive, unless you buy them from the ebay german parts seller deutsche auto parts in westchester you can replace the whole suspension on a non-4matic benz for 800 which is pretty damn cheap.
