Powerchip, is it worth it?
and sorry to go a bit off topic, but is it better to get our ECUs to be tuned by renntech?
thanks alot gentlemen.
AGE55 is refering to Powerchip. They're about $1000 for the S430 and S500 and they claim gains of up to 20+ hp, but I'm somewhat doubting it.
http://www.powerchipgroup.com/index.asp
Search up your car
thanks in advance.
I first thought the chip set was RT but found out that my model has the full AMG package less the engine. Brakes, wheels, tires, rotors, chip set, and suspension.
The first thing you notice is the throttle response from the changed mapping which makes the car take off and part throttle accelerate so much more effortlessly than stock. I have driven a few cars before and after.
evosport tests everything and they only use the best suppliers
There is a group buy on another forum for M3's at the moment - I think we need to get one on this board? Esp if I get my new car soon
The biggest difference you'll see isn't from the hp or torque gains, but the change in of area under the curve (on a dyno graph). That's the kick in the pants
However, on a NA engine (ie: non FI (duh)) you'll probably be better off saving your money and doing other modifications that'll cost less and possibly do more of a difference. To be totally blunt, save your money period and save up for a supercharger
W220 after 2003 got the change. S55 became supercharged and the S600 became turbo charged. Adding a chip to a TT engine can make a night and day difference because it's quite easy to just ramp up boost. On a supercharger system it's easy to add a pulley+chip to make incredible power.
For the S600 and S55 right now (the FI ones) I'd suggest contacting Euroteck (www.euroteckmotorsports.com) and getting the RENNtech Stage 1 (or Stage 2 if you want) packages for your car. The chip alone on the 600 is worth it.
