Steering Column Problem
Old Sep 28, 2006 | 06:55 PM
kelbo's Avatar
My steering column stopped moving up when I turn the ignition off. It also wont move up with the button. It moves in all other directions accept up. Has anyone else experienced this? Could this be a servo or fuse problem? I hope I dont need a new steering column.
Old Sep 29, 2006 | 04:33 PM
AMGS500's Avatar
W220 S500 AMG
sounds like a servo...
a fuse would protect the whole mechanism (i.e. 4-way movement).
Old Sep 30, 2006 | 10:32 AM
lloyds's Avatar
2004 CL500
have the same problem with mine, so i removed the fuse so it wont move down anymore.
Old Sep 30, 2006 | 02:20 PM
02S430's Avatar
W220 M113K
try to see if the knob that u use to adjust the wheel, the tip twist forward and back to stop or allow it to move when u put in or take out the key, try that it might work
Old Oct 6, 2006 | 12:24 AM
516mbtek's Avatar
'06 CLS55 P030
steering column
the motor is bad and can be purchased seperatly, but it is not easy to change
Old Oct 6, 2006 | 01:25 AM
kelbo's Avatar
Is this the part I need #A 220-460-07-25
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=220032717706&ih =012&sspagename=STRK%3AMEWA%3AIT
Old Oct 8, 2006 | 10:33 PM
516mbtek's Avatar
'06 CLS55 P030
I Dunno, I Quit The Dealership.....i Think All The Motors On The Column Are Interchangeable And Have The Same Part #...but Im Not Positive Abt That.
Old Oct 10, 2006 | 06:33 PM
kelbo's Avatar
I went to a local repair shop & he said he would run a code check to see if he could find the problem for $120.00. Does this seem right?
Old Oct 10, 2006 | 09:49 PM
516mbtek's Avatar
'06 CLS55 P030
i am telling you its the motor...i have done many for this problem...you have to remove the steering column assembly to replace it (properly). If you want to pay someone to scan your car they will find nothing and will not be able to diagnose the problem correctly anyway unless their scan tool can communicate with the steering column module...which most aftermarket scanners cannot. Buy the motor take it to them and say "install this" .
Old Oct 14, 2006 | 05:10 PM
kelbo's Avatar
I took my car to local parts/service place. The mechanic did something to the knob & it now works. It took less than 10 seconds & for free.
Old Oct 14, 2006 | 05:38 PM
Oxygen's Avatar
W220 S65 AMG
Owned.
Old Oct 15, 2006 | 08:15 PM
516mbtek's Avatar
'06 CLS55 P030
damn..he must be a majician...good 4 u, hope it LASTS bro
