Airmatic problem!!! Please help!!!!!!!!
Old Nov 11, 2006 | 10:46 PM
SUNILP's Avatar
2015 E250D
Originally Posted by IluvS500
which is why you stated before, if i recall correctly, to lower the car part way and turn it on to let them inflate before lowering it completely on the ground.
Yes, you are correct.
Old Nov 13, 2006 | 01:35 AM
locster's Avatar
can anybody tell me if special tools are required to change the compressor?
Old Nov 13, 2006 | 07:21 AM
SUNILP's Avatar
2015 E250D
no special tools required to change compressor.
Old Nov 13, 2006 | 08:57 AM
loredan's Avatar
S320
So,
last weekend I have try what 516mbtek suggest.
I have spray the top of the strut and slowly with hydraulic jack I lift the car.
As soon as the wheel where lifted from the ground I hear a crack noise and on the top the bubbles start.
I let down the car and leaking stop.
What do you think should I go to Mercedes for repair kit?
Is there any risk now in "normal" driving?
Old Nov 13, 2006 | 04:29 PM
locster's Avatar
I got the car fixed, thanks guys!
Just one more question, every time I raise the car I hear a loud vibrating noise (seems like the compressor is working very hard). Is this normal when raising the car or should I get this checked? It's a new compressor btw.
Also when raising the car should the front always be higher than the back? I checked the stuts and I dont here any air leaking noise.
Old Nov 13, 2006 | 04:59 PM
locster's Avatar
looks like the problem was not fixed
when i turn on the car i sometimes hear a loud vibatring noise at the beginning then it goes away, which never happened with the old compressor before
i took it for a test drive and that vibrating compressor noise kept coming on and off
is it safe to ride like that?
is this happening because it was not installed properly or could it be cause its a new compressor?
Old Nov 13, 2006 | 05:31 PM
  #32
fusion2007's Avatar
CLS 63 S AMG , s500,clk550
i think the compressor has a break in period... i say give it some a few days and if its not fixed then take it back..
I could be wrong though... although i have heard that it takes a few days for a compressor to break in.
Old Nov 13, 2006 | 05:37 PM
  #33
locster's Avatar
is it safe to drive like that?
seems like that is the only problem since the car has not lowered, it only vibrates on and off while im driving
Old Nov 13, 2006 | 07:15 PM
  #34
locster's Avatar
i wanna know if its safe to drive around like that because i need to drive to school soon
Old Nov 13, 2006 | 11:21 PM
  #35
516mbtek's Avatar
'06 CLS55 P030
the tech may have left off the rubbers that dampen the vibration...?
Old Nov 13, 2006 | 11:35 PM
  #36
locster's Avatar
I will check on that, thanks.
I need to use the car right now so I want to know if it is safe to ride around like that without anything bad happening
Old Nov 13, 2006 | 11:42 PM
  #37
516mbtek's Avatar
'06 CLS55 P030
you will be fine if thats all it is...
Old Nov 17, 2006 | 05:51 PM
  #38
locster's Avatar
I still hear the compressor vibrate on and off while im driving
is this something serious? should i get it checked?
sorry for being such a bother
Old Nov 18, 2006 | 04:43 PM
  #39
Mark_K's Avatar
2002 S430
Yes of course get it checked.
The rubber gromits may need to be replaced.
I had to do this on my Range Rover.
Old Nov 20, 2006 | 08:22 PM
  #40
hawk20's Avatar
E220cdi Estate Avantgarde March 2008
For goodness sake get to a Merc dealer. Complex cars need properly trained mechanics. You'll have far less hassle in the long run. Good luck.
Fantastic thread showing the amazing depth of knowledge available to us all here.
Old Mar 30, 2007 | 02:34 PM
  #41
locster's Avatar
I was told the compressor just needed to be put on but apparently according to Mercedes-Benz the "Compressor should be diagnosed and activated utilising SBD-102 or factory tool. This updated compressor requires (1) 220 327 00 82 hose and (1) 002 542 13 19 relay per Mercedes_Benz". Could this be why my compressor vibrates on and off on the road?
Old Jan 1, 2013 | 12:14 PM
  #42
314mercedes's Avatar
2000 S500
my new compressor is noisy too, i know i replaced the springs and caps in the order they came off....any comments?
Old Jan 23, 2013 | 10:40 AM
  #43
Supergenius40's Avatar
2001 S500
It's my turn now
My car is down and I've been without it for a week. I was blessed that it died in my garage. I bought my new compressor over the weekend. WOW just in time too, the price for the compressor has dropped. I paid $303 from AutoHausaz. Arnott also has them for $313.
My question is...will it come with new springs (bushings)?
Old Jan 23, 2013 | 06:29 PM
  #44
2000 S500
no sir it only comes as the pump itself, all mounting hardware is reusable...and so is the rubber bushings
Old Feb 5, 2013 | 04:00 PM
  #45
2001 S500
Job done now what?
Changed my compressor last week. As all the other installs on this car...easy. However, this thing is loud. Inside the car, outside the car sounds like I'm sitting in a tire shop. But it comes up like ummm very fast. Now my rear driver drops low. Added to the list.
Old Feb 5, 2013 | 06:36 PM
  #46
2000 S500
mines is loud to, i really don't know why, cause i installed everything as it was removed...if anyone has experienced this please let us both know how did ou get it quiet...i'm sure a service tech at mercedes would know, but the first words out there mouth would be bring it in, could have installed something wrong...lol
Old Feb 5, 2013 | 07:34 PM
  #47
2001 S500
Decade later
m thinking it might be I put it on too lose or too tight. Or it could just be a decade later the product changed. I notice no one is stating anything different but I'll investigate more.
Old Feb 5, 2013 | 07:43 PM
  #48
2000 S500
any tighter you'll end up buyin a new bracket like i had to do, and that was painstakin to install....i believe you have it on right, it was a simple install...
