RECALL - Instrument Cluster
Old Nov 15, 2006 | 01:27 PM
konigstiger's Avatar
'71 Pinto
Arrow RECALL - Instrument Cluster
Recall Campaign 20067080004 NOV06 Inspect Instrument Cluster (IC) and replace if necessary. Approximately 30,379 vehicles affected.
Model 215 (CL-Class), 2000 – 2002 / 2004 – 2005. VIN range:
215.373 = A010123 – A029012
215.374 = A043422 – A045438
215.375 = A007963 – A045436
215.376 = A043426 – A045418
215.378 = A007971 – A027788
215.379 = A043461 – A045427
Model 220 (S-Class), 2000 – 2002 / 2004 – 2005. VIN range:
220.070 = A153298 – A300137
220.170 = A137766 – A452109
220.173 = A159266 – A301296
220.174 = A432175 – A452076
220.175 = A137746 – A452124
220.176 = A432934 – A452122
220.178 = A137763 – A301366
220.183 = A431158 – A452129
220.184 = A431168 – A452126
Due to variations in the production quality of electrical components from the supplier, the background illumination of the IC may fail. Under certain conditions if the vehicle is driven after the background illumination fails, the IC fuse may blow causing a total failure of the IC. The dealer will check the IC part number and replace if necessary.
Notes:
(1) Every vehicle in the VIN range may not be included in the campaign. Call your dealer to verify that this campaign is required on your vehicle.
(2) If you paid to have this condition repaired, provide adequate documentation (i.e.: dealer invoice) to support a non-warranty repair to be eligible for reimbursement.
Old Nov 15, 2006 | 04:40 PM
newton22's Avatar
BMW E39
Yes, most of us are already well aware. Thanks though. BTW, where do you get all this information? I see you post recalls etc. in the 211 forums too.
Old Nov 15, 2006 | 05:38 PM
'71 Pinto
Originally Posted by fusion2007
next time search the forum before you post a thread
According to the bulletin MBUSA initial issue was 9/27/06 and updated 11/3/06
