Need Advice
I have a couple of topics I need covered here.
1. I have a crack going down my rear glass, can I have it repaired? Its not an external crack (i.e you cant feel the crevice, its internal) I assume it resulted from my back Lorinser spoiler from the weight of snow in the winter (might be the aerodynamic force from highspeed cruising) The warranty doesn't cover accessories, I got it in Dec of '04 with 30K with the spoiler, when it was certified, but they tell me it doesn't cover accessories anyway.
The length spans the entire glass vertically, not entire but almost to the bottom.
2. I have another more severe crack on my rear passenger side window, the size of an index finger, it looks like someone took a pen sized object and punctured it, most likely trying to break the thick-sound proof MB glass.
3. I need to touch up the car (paint). A couple of scratches in the back, a thumb nail sized dent on the side. a couple of scratches in the front.
4. Also the car has paint taken off the bottom of the front bumper (most likely from leaving a drive way or a parking barrier in a lot)
What will each issue cost me?
Thanks!
BTW, these pictures were taken fresh off the lot in '04
Paint - expensive if you are painting the entire car. $4500-8500 depending on which paint you use. You could touch up those minor chips then use clay and seal for a fraction of the cost of paint. Most peaople here like the Zaino product line. Try that and spend a whole day to see if it makes a difference before you think of painting. Then again like you said you can afford a new S550 so that means that cost is no option.
Thanks!
http://cgi.ebay.com/ebaymotors/2003-...QQcmdZViewItem
This should help with the back glass.
I won't spend 4500 to paint the car anew, thats just throwing $ into the wind.
I remember spending $200 to repair a dent on my FX (a 2 foot dent) and he painted a couple of chips on the car. The S-class doesn't have and dents just a couple of chips in the front and back. So I figure $300 max.
I also want to put new rubber on, whats good for the Sport? Dupont Sport Maxx? I have SP9000 on there now, but its $250 a tire! I want to spend 150-200. I'm not exactly taking it out to the track. Something for moderate performance, to keep in in a straight line. These are 18 inch rims.
