Holy leak-fest Batman!!!! Did I get f'ed?
Old Jan 8, 2007 | 10:19 PM
Aleksandar's Avatar
2000 S500
Took the car in last week to fix some leaks. Allow me to show you how this looks on paper, you guys tell me if I got f'ed.
Electrical connection seal-$4.15 (x2)
Transmission Pan Gasket-$12.95
Part cleaner-$3.95x4=$15.80
MB Automatic Transmission Fluid-$12.90x10=$129.00
MB Sealant-$12.90x2=$25.80
MB Fasteners-$6.90x2=$13.80
Mobil one synthetic engine oil(5w30)-$5.95 x 8 =$47.60
Grand total for parts=$252.90
Onto labor.
Remove lower front paneling, clean off fluid leaks (took 1+) at a rate of $95 an hour=$152.00
Install new transmission pan gasket, new electrical connection seals (took 3+ hrs) at a rate of $95=$304.00
Remove, clean off sealant, reseal engine pan (took 4+ hours)=$437.00
Total labor=$893.00
Plus misc. fluids (topped off all the fluids)
Total damage=$1196.68
Ok, did I get f'ed on pricing or is this fair?
Thanks guys
Aleksandar
Old Jan 8, 2007 | 10:37 PM
newton22's Avatar
BMW E39
On labor? Yes.
Old Jan 8, 2007 | 11:47 PM
ProV1's Avatar
MB, BMW
did they give you some lube b4 ramming your a$$?? ouch!!
Old Jan 9, 2007 | 12:37 AM
fusion2007's Avatar
CLS 63 S AMG , s500,clk550
i hope they did!! probably charged u for your that too.. id be concerned about the labor go back and talk to them if u can
Old Jan 9, 2007 | 07:48 AM
Mark_K's Avatar
2002 S430
It is what it is.
You knew that these cars are expensive to maintain.
Is it expensive? Yes Did you get f'ed? You f'ed yourself when you bought a car that you aren't welling to spend lots of money on and didn't by a warranty.
Having said that, it is very expensive to own these cars. I feel your pain.
Old Jan 9, 2007 | 09:12 AM
RobertG's Avatar
things with and without wheels
It took them 2 hours to remove the belly pan and clean off the oil?
Old Jan 9, 2007 | 09:27 AM
kenstudios's Avatar
Labor runs between $150-200 an hour. Some techs even charge to run diagnostics.
Old Jan 9, 2007 | 11:08 AM
RobertG's Avatar
he said that labor is $95 per hour.
I dont see how it could take someone 2 hours to drop the belly pan and clean the area
When I worked piece work i had to argue with the sevice manager over diagnostic time or any other time consuming job that doesnt pay much.
Old Jan 9, 2007 | 11:17 AM
jmf003's Avatar
'03 SL55
Piling on here....
The 3+ hours to "Install new transmission pan gasket, new electrical connection seals" and the 4+ hours to "Remove, clean off sealant, reseal engine pan" seem way too high.
If it were me, I'd probably have a "this can't be correct" conversation with the service advisor, escalating to the service manager if needed.
Good luck!
Onto labor.
Total labor=$893.00
Thanks guys
Aleksandar
Old Jan 9, 2007 | 01:47 PM
fusion2007's Avatar
alexander is this your first mercedes? if soo the guys at the shop new that and decided to screw you...dont worry it happend to me too 8yrs ago
Old Jan 9, 2007 | 02:16 PM
Vader55's Avatar
AMG E55, Stage 1, Strait Pipe from Primary Cats
Originally Posted by newton22
On labor? Yes.
+1
Old Jan 9, 2007 | 11:20 PM
Aleksandar's Avatar
2000 S500
Annnnnnnnnd, the drama continues. It wasn't the tranmission gasket that was leaking. It's the TC front seal (above it). I took it back into them (Harrison Connor Automotive in Scottsdale), and he refused to do anything about it, saying his 10 hours of labor is "valid and done correctly". Let the fun begin.
Old Jan 9, 2007 | 11:22 PM
Aleksandar's Avatar
2000 S500
Yes, its the first time I ever took it in to someone else than my mechanic (who is overseas in Europe, hence me taking another member's recommendation), and yes, I got taken for a fool. The transmission gasket should take twenty minutes to change (given its location). So now I get to see how to recoup my 700 dollars + (at my estimate) I got taken for at Harrison Connor Automotive (As recommended by another member).
Lesson learned. Car's at the dealership now. I expect many more expensive repairs. Gotta love it.
Old Jan 9, 2007 | 11:23 PM
Aleksandar's Avatar
2000 S500
Originally Posted by Mark_K
It is what it is.
Completely understandable, but I'm not concerned about the maintenance as much as I am getting RIPPED off for my hard earned money, and that isn't fair.
Aleksandar
clkwork's Avatar
CLK63 Black Series
ouch
Old Jan 10, 2007 | 09:40 AM
winmaw's Avatar
2000 S500, 2001 Camry,1996 Honda SUV
My mechanic (specialized in MB) replaced the front seal, transmission oil 9 qts (they are able to drain TC), filter, gasket, electrical connector and charged $ 940.00 including material + labor.
Old Jan 10, 2007 | 09:56 AM
ex-BenzDriver9's Avatar
LX470
Where in Jersey are you? I need new front rotors and an allignment and I don't want to deal with the stealerships.
Let me know if you know of any mechanics in Hudson Co.
Old Jan 10, 2007 | 10:05 AM
RobertG's Avatar
Can't argue with the "valid and done correctly" but you can argue about the misdiagnosed part of not finding the leak.As a rule of thumb of working on any leaks, always check before you start work and after a road test.
If you payed with a credit card see if you can stop payment that will get their attention.
Old Jan 10, 2007 | 10:33 AM
Aleksandar's Avatar
2000 S500
Unfortunately, I'm one of those "cash only" suckers. (I got screwed by identity theft a few years back, so its cash or nothing for me these days, hence why I drive a 2000 S500 and not a 2007 S550). I will go bother them some more this week, see if I come up with anything good.
Old Jan 10, 2007 | 11:20 AM
winmaw's Avatar
I am in fort lee (Bergen). My mechanic is a guy named "Zenop Tuncer" from Eurotech Motors (edgewater, 07020). Ph 201 941-2111.
Old Jan 10, 2007 | 11:52 AM
LX470
AWESOME! Thanks for the info! Will he do rotors by any chance?
Old Jan 10, 2007 | 11:59 AM
winmaw's Avatar
I am sure he will. He is very good in european cars and you will see all the cars he is doing in his workshop.
Old Jan 10, 2007 | 05:47 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Onto labor.
Total labor=$893.00
Thanks guys
Aleksandar
Be fair here...
Any time you turn your car loose with a dealer service center or any shop for that matter for troubleshooting, you are at their mercy.
What you should have done was gotten a written estimate first, then, asked questions like why you were being charged 12.95 for a quart of transmission fluid. I know you can get tranny oil for less than that!
3.95 for Parts cleaner? @ 4 cans? you couldn't have pressure cleaned you car first? give me a break.
Q.
Was this a mercedes dealership? because the way this is itemized looks like you paid premium prices for shop supplies which are normally included in the work. This is not a normal practice at most dealerships.
Since you asked, Yes you got ripped but you should have not excepted such a high estimate for such small amount of work anywayz...If you didn't get an estimate prior,
1. let this be a lesson to you.
2. If you must pay high maintenance fees, at least pay it to a reputable dealer who will standby their quality.
To the extended warranty peddler ^.. This is NOT another reason to buy extended warranty. MOST EW's out there don't even cover leaks from seals,
or gaskets.
THe lesson learned here is : Even if you can't turn a wrench, you should be able to shop around till you find a reasonable quote for getting work done on your car. Since this wasn't an emergency visit you had every opportunity to refuse to let this shop work on your car at such an expense and shop around for a better deal.
Yes these cars can get expensive especially if you don;t know how to operate a wrench. However, this IMO is a very exaggerated of an expensive repair, and this would have happened to this guy if he had driven his Buick to the same shop for the same repair.
Old Jan 10, 2007 | 07:22 PM
epj1906's Avatar
'03 S55 AMG, '01 CLK55 AMG
Onto labor.
Total labor=$893.00
Thanks guys
Aleksandar
Typical dealership costs. Of course you got screwed, but anytime you take a car into a dealer for any sort of maintenance, prepare to pay out the azz.
Case in point, I have a '96 Pontiac Trans Am that had a bad starter. The dealer wanted to charge me a grand total of $700 parts and labor for the job. Took it to Pep Boys and they quoted the job for $200. I ended up buying the starter off Ebay for $85 and paid a local mechanic $75 to do it in my driveway.
Dealers make tons more profit off repair work than they do selling cars....... you don't think they are going to change this process do you?
