Directions on removing headlight in order to install ballast - HELP
Old Feb 3, 2007 | 05:00 PM
ArMaNi S500's Avatar
2000 Mercedes S500
Can someone help me locate instructions on removing the headlight in order to swap the ballast? Thanks!!
Old Feb 4, 2007 | 02:51 AM
Vader55's Avatar
AMG E55, Stage 1, Strait Pipe from Primary Cats
Here is copy of a post of mine that should help
The hardest part is getting the old lamps out, putting the new ones in is easy. be sure to remove the 2 - 8mm bolts on the top of your bumper located on the inside area of the the headlamps for wiggle room that you will need and just remove the 2 - 10mm bolts securing each lamp and carefully wiggle them out, steel like knobs stick out of the fender side of each lamp so each lamp needs to pulled towards the center when taking them out.
Old Feb 5, 2007 | 03:04 AM
KENNETH04S's Avatar
02' brabus modified ML500,05' Lambor Gallardo, 02' CLK
uhhhh...... why take so many steps???? in my S430, i just open the plastic cap cover, unbutton the lock and take the bulb out, plus your car is a 2000 model so i'm pretty sure u don't have " stock HID" in your car, so...why there is a "ballast"???
Old Feb 5, 2007 | 01:59 PM
Vader55's Avatar
Year 2000 and up S500's typically have "stock" Bosch HID lamps and the ballast is located on the underside of the lamp. We are "not" talking about changing the bulb here grasshopper, the bulb location and ballast location are in compltetly different areas of the lamp
ps.Most S430's do not have "stock" HID's
