Keyless Go
Old Feb 24, 2007 | 05:38 PM
RomansDad's Avatar
Lamborghini Countach, BMW M3, ML 500 x2, S500 Lorinser
Keyless Go
Can anybody tell me what happens if you walk away from a keyless go with the engine on and the key in your pocket? Im curious, but I dont want to do anything that might screw up the car.
Old Feb 24, 2007 | 06:07 PM
mbtech360's Avatar
Im not sure exactly what will happen, i think it will shut the car off as long as its not moving. I wouldnt worry about it messing anything up
Old Feb 26, 2007 | 09:47 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
If you leave the car, engine running, and having the KG-Card in your pocket, the car remains running (and someone can drive away). I don't know if it keeps running until the gas tank is empty?????? because nobody can switch it off w/o the KG-card or a key.
Old Feb 26, 2007 | 02:10 PM
sprink49's Avatar
2004 S500
I know mine will run untill I push the on/start button...that turns it off.
Old Feb 26, 2007 | 03:51 PM
pmrogers's Avatar
2013 SL65 45th Anniversary Edition, 2014 Range Rover Sport Autobiography
It should turn off at the first stop after 10 minutes
According to the manual for my '03 SL55, the keyless go would turn off at the first full stop after 10 minutes out of range, or something like that. I never tested it. It makes sense, though, as a way to blend safety and convenience. You don't want the car turning off immediately if you run back into the house because you forgot the grocery list or something. And it's a way for you to get safely out of a car-jacking situation without giving the thief completely free control over your car.
But again, this is based on recollection of the manual for a car I sold 2 years ago.
Paul
Old Feb 26, 2007 | 09:18 PM
why_not's Avatar
W212 2009, W115 Pullman & EQC
My cls did run for two hours .. iforgot to stop it..
-it did not stop..!.. and i was NOT in range
/kim
Old Feb 26, 2007 | 09:21 PM
TREZ63's Avatar
2010 RRS ; BMW K1200R; 14 E350 ; 14 RRS on order
Should run until turned off.
Old Mar 1, 2007 | 05:09 AM
KENNETH04S's Avatar
02' brabus modified ML500,05' Lambor Gallardo, 02' CLK
I tested it, after i drive away from the key, it popped up red screen with a fast tone like u don't wear your seat belt and then turned off. And then i tested with not-running away....the car sit like a dog waits for the bone...it stayed on.....
Old Mar 1, 2007 | 12:32 PM
RomansDad's Avatar
Originally Posted by KENNETH04S
I tested it, after i drive away from the key, it poped up red screen with a past tone like u don't wear your seat belt and then turn off. And then i tested with not-running away....the car sit like a dog waits for the bone...it stayed on.....
I have absolutely NO IDEA what this means....
