OBDII P0170 Code
I ran the car at Autozone today. One code "Fuel Trim Malfunction p0170". I closed the Fuel Cap properly and the sign disappeared. Hope it won't appear again!
I hope it has nothing to do with the 02 Sensor or MAF.
However my car was motionless in the driveway for a while so the dust must have developed on it. So once I took it on the highway and gave it a breeze, it was A.O.K.
Any similar experiences?
In my case, it was the MAF sensor (my codes were P0170 and P0173 I think if I remember correctly). Cleaning it may help. My CEL light comes on occasionally still and I believe its my dirty air filters causing it.
Don't be surprised if the code comes back.
I actually had the filters changed and the housing cleaned 2 days ago. Cost me $50 for 2 filters. Was I riped off?
* http://www.mercedes-benz-parts-direct.com/epc-items.asp I guess not that badly, considering they need to be shipped.
I also covered her up, to prevent dust from latching on and stuff.
P0305-Cylinder 5 Misfire
P0307-Cylinder 7 Misfire
P0300-Multiple Cylinder Misfire
P0173-Fuel Trim Malfunction (Bank 2)
Like to diagnose and fix my own car issues, but may have to take to dealer should this persist...any suggestions/comments? thanks!
Also you can try and clean it,crc brand maf cleaner and then check o2 function.They are due at 100k miles and check cat function.IR temp gun makes that chore easy.
