600 Owners - Spark Plug Replacement Interval
Old Apr 10, 2007 | 07:13 PM
v8plus4's Avatar
2024 AMG G63, 2023 Bentley GTC Speed
Hi all,
How many miles are spark plugs typically replaced on a V12 engine (02 CL600).
Thanks in advance,
v8+4
Old Apr 11, 2007 | 08:27 AM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
Just checked the FSS sheet and it says it's recommended at 60,000.
Old Apr 11, 2007 | 09:25 PM
v8plus4's Avatar
Thanks, fool
I was told 60k or 5 years by the dealer.
Car is in for a B service. I was quoted around $600.00, and now the bill is coming in at $2500.00 (just maintenance, no other repairs needed).
Dealer said spark plugs were due, but I would have thought they were good for 100k. Car is an 02 CL600 with 40k miles.
I guess thats why they call it the STEALership.
v8+4
Old Sep 28, 2007 | 05:12 AM
johnlovescar's Avatar
Originally Posted by v8plus4
Thanks, fool
v8+4
That is the highest price I have seen on this form for the job you have indicated........... Bad Dealership...
Old Sep 28, 2007 | 10:01 AM
platt-deutsch's Avatar
2019 S450
I just replaced mine myself..took about 3 hrs..61,000 miles.
The old ones looked ok but hard to tell by looks. I paid 9.60 ea for the plugs from Europarts..
Old Sep 28, 2007 | 02:26 PM
ess600's Avatar
s600
3 hrs! wow, it sounds like some were pretty hard to get to. would you mind posting a how-to page?
Old Sep 28, 2007 | 02:57 PM
2019 S450
First take off the air ducts and the air cleaner.
Remove the wires to the coil paks.
remove the coil paks by removig 4 bolts. (special Torque head M12 but a 8 mm socket will work..
Then pull straight away from engine.
Pull all the red rubber boots off the plugs.
5/8 spark plug socket and remove the plugs.
install the new ones with anti seize compound on the threads.
Install all new boots with small amount of Silicone dielectric grease on each end.
Carefully slide the coil paks back on and reinstall all the bolts but be careful not to strip them out.
Done
Old Sep 28, 2007 | 11:18 PM
Dixit's Avatar
04 S55 AMG
Does that same 60k interval apply to the biturbo V12s?
Dixit
Old Sep 29, 2007 | 03:18 AM
whoover's Avatar
'19 E63S sedan
Dixit
Yes.
Old Sep 29, 2007 | 09:02 PM
Done
I assume there were 24 spark plugs. I this correct?
Old Sep 29, 2007 | 11:48 PM
2019 S450
Yes.. 24 plugs total..
