Fuel Filter Change
2002 S430
Fuel Filter Change
I took my car in to the dealership for Service A and they recommended that I replace my fuel and air filters.
They want $260 for the Fuel Filter change and $135 for the Air filter change.
I looked up the cost of the parts and they are both about $35 each. I can handle the air filter change.
Has anyone changed their fuel filter and is it a big deal to do? Any pictures or advice on this?
I figure it should be pretty straight forward as its a fuel filter. A couple of clamps and I should be good to go no?
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
If you found one for 35 let me know where because I can't order that cheap. I found them for 49 bucks which is not that far off. The dealer wants 120 for one.
2002 S430
The Air filter(s) are about 35 for both and easy to change. The fuel filter is not hard to change and is located along the lower right side of the car at the rear.
Moderator, delete the link please if i am not allowed to post non-sponsor links.
Thanks.
Found them here: http://catalog.worldpac.com/buymb/02...uymbparts.com/
Thanks.
Thanks.
2000 S500, 2001 Camry,1996 Honda SUV
I don't want to against anybody.
It is true that fuel filter is easy to change, IF you have changed it before on any other cars. But, You still have to consider the pressure build up in the fuel line. IF you are doing it at home and using the ramp with hand lights, Please do not take a risk. IF Fuel sprays on the hand light, it is very easy to catch fire.
Get the fuel filter on line about $50 and go Indy shop you ever went and tell them to replace it. It won't take long and it should cost you less than $80 for labor. It is worth to spend that type of money.
1 Post
2004 S500 & 2011 Mini JCW
You are correct! There will certainly be fuel sprayed when the pressure end of the fuel line is diconnected. I have not changed a W220 filter, however I have other cars with pressured fuel lines and I was sprayed!
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
I would venture to conclude that if a person has not the C.S. to realize that METAL fuel line could be under a bit pf pressure on a Fuel injected vehicle... Which most cars today are, he shouldn't even try to change a flat forget about the fuel filter job.
BTW.. it's not the fuel but the vapors that ignite.... and if your flashlight is so powerful that it ignites fuel, maybe you should be using a bit less of a light there pyro...
355 F1 Spider & ......V12 w220.176
Here is something I found on the net
http://www.techguys.ca/howto/fuel_filter.html
Seems an air filter change might be a simple change. The fuel filter still might be best left to a dealer.
I respect what you are trying to convey here but..
OMG.. If you try to follow these procedures on your mercedes, you will end up at the dealer for sure..
Depressurizing your fuel system is the way to go if you can't figure out how to remove the filter without gettin sprayed. Its easy on a benz because there is a release on the fuel rail. An should only be depressed when the car is off.
But starting the car and shutting off power to the fuel pump till it runs out of gas?? On a Benz?? can you say 'Check engine light??? You might as well call the dealer and make and appointment while your car is still idling..
This is why some people should just take their cars in for work and leave the maintenance to the folks that know how to do it.
Some of these generic How-to guides should be called how-not-to guides on certain applications.
