A different Airmatic problem?
So I have searched all the airmatic problem posts and have not been able to find anything like the problem I am having. So hopefully someone maybe know something about it.
The car is a 2002 s430. About 3 days ago I was driving it n the highway around 80MPH and the "Airmatic problem visit shop" message came on. The car felt no different and I continued on my way. Later that day I got back to the car, it looked normal, was not low. I started driving it an no messages. Once i got back on the highway again though the message came back but the car felt normal.
I do understand the car lowers it self at higher speeds, so I thought may it was not lowering itself at high speeds. So then two days later I was driving it again again the message appeared again on the highway but no change in the feel of the car.However once I got to where I was going I noticed
that the car was much higher ( as in raised up). The car then sat for a day and when I returned the car looked like a 4x4. I started the car and no change. I had to drive it and it drove ok other then being much more firm.
Again the car has sat for a day or so and no change. It is lifted as high as it can go? There has never been any noise of air and i have never heard the compressor running.
Sorry for being such a long post. Any help or suggestions would be greatly appreciated!
1) There is a problem with ride height sensors telling the system the car is too low. Or,
2) Your airmatic relay failed (on), and that is coupled with a failure of the pressure release function of the system causing the struts to extend.
Also, the car should automatically lower only if you are driving it in the raised position. Normally this is done only for rough road surfaces, or (perhaps) to clear a curb after scraping your bumper on it (damn curbs!). Raised is not the normal driving position.
Get it checked; don't keep driving it like this. You DO have a problem.
BTW...if you hear the compressor running with the car off, immediately pull the relay to avoid ruining the pump.Good Luck.
