Squeeking - Squealing Door Seals
Hi,
My car goes squeak-squeak-squeak over every bumps. I thinks my doors is making that noise when touching the door weather seal.
Is there something I can do about it ?
is it very loud? I know on my c240 I had a very loud squeek coming from the rear and they fixed some knuckle joints under warranty, said it was a common problem with mercedes.
however, if you're sure its the door seals goto a parts store of some sort and get Silicone Lubricant in a can and spray the weather stripping and door jams with it. its clear and you can't see it, but it should eliminate the friction causing such a squeek.
