interior filters renewal w220
MB S320CDI 2001, VW Golf Variant 2001, BMW E36 328I cabrio 1998
Hello aLL.
I tried to search but did not find on this (or any other ) forum
I am looking to renew my dustfilters(or pollenfilters) and the charcoal filters.
Where are they all located in a w220 S-class.![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Someone told me to take out the glove compartment for the charcoal filters. I tried the 4 visible screws in the glove box, but I could not take it out. What did I miss/do wrong?![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
Are the dustfilters/pollenfilters located there also??![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Any helpout would be fine, but picture are the best for me.
And yes, I have an S-class and still try to do all the maintenance myself
(as far as I can), but that is why I can drive it along with my BMW ragtop
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Hello aLL.
(as far as I can), but that is why I can drive it along with my BMW ragtop![drive](https://mbworld.org/forums/images/smilies/driving.gif)
http://www.boschautoparts.com/NR/rdo...stallation.pdf
2004 CL500
hi kor
The dust fillters are indeed behind the glovebox after taking the 4 screws out the glovebox should just pull out. You might have to push the top area down in order to clear the dash, disconnect the release cable and the light wiring to compleat. The 2 dust filters are behind a small cover.
The charcoal filters are actually accessible from underneath the dash directly under the glovebox. Just pull back the carpeting a little and remove the plastic cover under the dash and you will see the charcoal filters cover Slide it away and replace with your new ones as it also needs 2 filters.
Best of luck
Best of luck
Hello Whoover, Lloyds,
this is indeed the info I am looking for.
I am going to try it with the tips/instructions.
Many thanks for your efforts.
