Add Satellite Radio to 2005 S500?
Also, does anyone know where the satellite radio gets plugged in?
Martin
Martin
The receiver "plugs into" the MOST fiber optic ring. You will need a dealer or other tech with access to a Stardiag system to recode the ring controller for the unit to work. Until you recode it you will probably have problems with the audio, phone, nav, TeleAid, etc.
There are a zillion antenna options other than drilling. Magnet base or stick-on works well and can be purchased from crutchfields.
With MOST you should not have to version code the SAT. it will identify the SAT module. Either way it's only 1hr. labor Ifits even needed.
BtW. $1100.00 is for parts ad labor. If you ask fpr the Kit you can get it foe about $450.00 from the dealer depends on who you call and how desperate they are.
http://www.mercedestechstore.com/pdf...2004-23-04.pdf
These cars all have a personality of their own so things just don't work the way it is written most of the time.
There are no exposed wires with the Stick-on, if its done right. The stick on I used came with a small wire channel that butted up to the back of the antenna.
FYI. The Factory install on my E was a stick-on. on top of my Pano-roof. I undid their crappy work and remounted it on the trunk facing up like it was supposed to be.
My w220 has the drilled antenna. I do like it better but it's just a whole so if you know how to handle a drill it's not rocket science.
The spot where the whole goes is already marked if you have the factory trunk. and there are plenty of instructions posted on installing the drilled antenna. The stick-on is just easier and just as clean. ( see Pic )
I just noticed you were in the Bay area.. I was just up there last week in Calistoga.. Very Nice area!!!!
