HELP:Install brake wear sensors '02 S500
Old Oct 17, 2007 | 03:36 PM
DTMLGND's Avatar
'93 Porsche 964 C2 Coupe(DD), '16 Audi A6 S-Line (wife's DD)
Anyone have any insight on installing brake sensors on 02 S500?? Is is relatively easy? My warning light has come on regarding brake wear and the dealer I bought it from sent me 2 sensors (fr/rr). He claimed they were both on the drivers side and easy to pop-in. Any help would be greatly appreciated.
Thanks,
Pau
Old Oct 17, 2007 | 06:07 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
How odd. Are your pads new, or worn? If the sensors weren't replaced when pads were, they should have been. If they're worn, replacing the sensors won't fix them.
In many states, cars cannot be sold unless they pass a state brake inspection even if transferred between private individuals. Evidence of the successful inspection is required before the state will title and register the car.
You might pursue this a bit.
I hope you don't need surgery soon. If your doctor is like your dealer, he'll just hand you the scalpel.
Old Oct 17, 2007 | 10:16 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Thanks,
Pau
They are easy to pop in but they will last a day if you're lucky if you install them on worn pads.. The other sensors went off for a reason. next stop you'll be replacing rotors due to the damages... Don't mess around with you brakes it could get expensive especially for you since you do not appear to be a DIY'er.
Old Oct 18, 2007 | 12:34 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
It is a waste of time to change the sensor if you have worn pads.
here is a link on brake jobs
https://mbworld.org/forums/s-class-w220/169374-brake-job-instructions.html
if you have new pad the sensors are cheap.
