Check Low beam
Old 11-09-2007, 10:03 AM
estrain_ny's Avatar
2001 S500 and 2000 BMW 740I
Check Low beam
Guys tell me if this is worth taking to the dealer. I started noticing the same malfunction on my car. The low beam, it goes out sometimes, but when I shut the car off and restart it goes away.
Have amyone experience this before and what can I do to eleviate.
Old 11-09-2007, 01:12 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Have anyone experience this before and what can I do to eleviate.
Sometimes this happens when the bulb is going bad.
Try changing the bulb first because that's more than likely what the dealer is going to do anyway.
Old 05-22-2008, 10:37 PM
S500Sport's Avatar
2019 C43 Sedan
i would say check the fuse first.. Am I right?.. I have the same malfun..
Old 05-23-2008, 08:43 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
And if the bulb change doesn't help, you may need to replace the ballast.
Old 05-23-2008, 12:03 PM
rccmerc's Avatar
I assume you have xenon low beams. If so most likely the xenon lamp/burner is on it's way out. One way to check is if the lamp has a blackened section, it is on it's way out. There probably is a stored code, but if it is intermittent it will not show in your messages in the instrument cluster. If you go the dealer and it is the xenon lamp they willc harge you an arm and leg for the lamp.
Quick Reply: Check Low beam
