Airmatic relay, problems?
Following occured today: Driving for about 20 mins, when i slow down in road cross i can hear the compressor going. Driving 5 more min to home, still running. Even with car shut off; still running. since i knew in wich fuse box relay was supposed to be, i started to pull the relays till it stopped. Relay has part no A0002 542 1319.
After i put back the relay to test it, the compressor didnt start. Then i start up the car and the compressor runs until pressure is ok then turns off.
So shall i suspect that the relay has a beginning failure ?
I am also having problems that the right side back is lower than the left side back. Even when i run the lift switch, the right side does not lift as high up as the left rear side. Could this be the level sensor is bad ? or the calibration setting needs adjusting ?
Since neither the back or the front sinks completely to the bottom with the engine not running over the night i guess i have no air leaks ?
So if someone could help me pinpoint theese problems or give their opinions would be appreciated.
Rgds
Odd
Norway
Rgds
Odd
Norway
I changed the relay, with the Hella one, pump is running a lot less now...
The old relay really buggered the pump.
I am 100% sure since the car stays constantly lower on the right side back at the same elevation all the time, must be a problem with the sensor or the sensors calibration settings, or possibly the valve on the main block is bad.
I am very satisfied i read about the problems with the relay, so that when the pump really started to go for long periods i knew i had to stop it...
Thanks to the forum!
Rgds
Odd
My parents' vehicle ('02 S430) recently had its air compressor replaced by the MB dealer. They also replaced the OEM (air suspension) fuse that is in position "O" with the Hella type.
My question is this...does the (secondary air pump) fuse that is in position "N" also need to be replaced since it is the same (inferior) type as the fuse that was originally used for the air suspension?
By the way...positions "O" and "N" are referenced from the Information Page for Relays and Fuses that is located in the trunk above the spare tire.
It would help if you had given us the model year of your car; but an '01 diagram is at http://www.benzworld.org/forums/w220...e-diagram.html. The fuse boxes are all in the same locations for the W220; but individual relays, fuses and amperages may be different in different years.
Just FYI, the fuse box depicted near the rear seat is behind the passenger side courtesy light for the footwell. The panel pops out. You do not have to remove the seat. However, the relay you need to access is in a engine compartment box.
