Airamatic Issue?
i inspected the height at like 4am and 7 and everything was perfect.
This should help. Also maybe good to invest in the Carsoft software to diagnose problems, it can be a lifesaver if the car is not under warranty.
p.s It was the back left, not the front, both front were good.
Trust me, once is leaking, unless sealed, it will spread to the point you'd have to tow your car to the dealership. Just go an get it sealed.
lucky the front strut was replaced a month a ago by a local shop ''''''i called them they will reinstall another strut .....i will have them seal the other and replace with a used pump.....maybe it might only cost me 700.00
I've nade an appointment for 8 am Friday for Service B, he will change OIL and the rest if there is something, he'll do it. OIL is $150 though.
As for MB Soverign My Local Benz Dealer they Quoted $399 for service B.
It went on for you once, then it went away? and came on later again?
Airmatic came on again last night at 5am for a few seconds, then gone.. ahhh
leaking struts or sensor is a bit ****ed.
Need to schedule this appointment asap.
As an '02, it has no factory warranty unless you were somehow able to get it Certified Pre-owned (unlikely).
The dealer may have specified that the car was "as is - no warranty" if state law allows that.
On the other hand, some states impose limited warranty by law for a specified period - 30 to 90 days. Warranty coverage would vary from state to state. But it's worth asking, since you posted on December 29 that you had just bought the car.
On the other hand, the dealer may have offered a warranty of some (short) time.
At least, ask before you pay. But do get it fixed.
Cost to repair Airmatic leaks depends on what is leaking. New upper strut seals (with new metal mounts) cost me $550. If the lower seals are leaking, each front strut is $1300 (I believe that's parts & labor) and they are normally replaced in pairs. I don't know the cost if rear struts. The Airmatic pump is $900 through a dealer, but search the forums; I have seen them for much less.
Espcially when in my case, I think there is nothnig major as when it turned on 2nd time, everythnig was prety much High and even...'
but yea, Ill go to a shop and have them checkit all out.
