Nav System
Old Jan 10, 2008 | 08:12 AM
Gnaigle's Avatar
2018 GLE350 4matic
Nav System
My nav system will all of a sudden just stop and eject or say the Nav disc needs to be changed, I remove the disc and put it back in and it will just spit it out. Other times will work fine! Any ideas?
Old Jan 10, 2008 | 08:55 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
My best guess is that the laser is dirty, the disc is dirty, or the disc is damaged.
Old Jan 12, 2008 | 08:39 AM
Gnaigle's Avatar
2018 GLE350 4matic
Anyone know how you clean the laser?
Old Jan 12, 2008 | 10:33 AM
dav818's Avatar
W220
there are cds that clean the laser
Old Jan 12, 2008 | 11:17 AM
LetsJet's Avatar
355 F1 Spider & ......V12 w220.176
Can you put in another cd in the Nav and see if it's just the cd?
Old Jan 12, 2008 | 06:04 PM
Skylaw's Avatar
Just be sure it's another nav CD and not a music CD when you check.
Old Jan 12, 2008 | 07:34 PM
Gnaigle's Avatar
2018 GLE350 4matic
When I put in another section cd it just tells me to change cd's. I purchased a cleaning Cd but can't tell if it's running or not, or how long it should stay in as it tells me to change the cd within a few seconds. this said other times the Nav system works perfectly.
Old Jan 13, 2008 | 09:11 AM
Skylaw's Avatar
You may need to re-flash your COMAND firmware. Your dealer can do it. In any case, this will require diagnostics that your dealer or a good independent MB tech will have to address.
