Dash lights are out
Old Jan 30, 2008 | 10:16 PM
thebigsicilion's Avatar
Dash lights are out
2003 S600
Can someone tell me which fuse is for the instrument panel lights? For some reason my fuse chart is not where its supposed to be.
Old Jan 30, 2008 | 10:43 PM
Vader55's Avatar
AMG E55, Stage 1, Strait Pipe from Primary Cats
Originally Posted by thebigsicilion
2003 S600
There is a factory recall on clusters so check on that with your vin at any dealer
Fuse chart link
http://www.benzworld.org/forums/w220...e-diagram.html
Old Jan 31, 2008 | 05:16 PM
mugsy415's Avatar
2007 S550
2003 S600
Your cluster is bad. Take it to the dealer there's been a recall on it. Mines went out this summer. Don't let them toy with you either by sayin "certain vins are only covered."
Old Feb 1, 2008 | 01:36 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
BigSicilion,
If you mention "recall" the dealer may go into the VIN matching neverland and waste your time. He needs to look for information on the extended warranty (10 years from date if initial service) that is not dependent on VIN - and don't take any other answer except that the cluster is covered by the extended warranty!!
There have been many misunderstandings over this, because the whole thing stated as a recall that was later changed to the extended warrantee. Jayhawk posted a copy of the warranty letter that succeeded the recall at post 58 at https://mbworld.org/forums/showthrea...t=82722&page=2
Old Feb 2, 2008 | 09:17 PM
mittalv's Avatar
2014 GL450
dash lights out
i am sorry to tell you but you will need a new dash unit
the GOOD news is that it is covered by a recall!
Good luck with your dealer
Old Feb 3, 2008 | 12:02 AM
naijaman's Avatar
2000 S430, 2002 Range Rover HSE 1985 BMW 535 (Sold), 99 BMW 530 (R.I.P), 98 Mazda Millenia (R.I.P)
My dash went dead last year, and I took it back to the stealer due to the recall, and it was replaced for free. No problem since then.
Old Feb 3, 2008 | 03:58 AM
lernik21's Avatar
s500
Thumbs up
I had the same problem last week and it was a fuse. The fuse is located on the driver side fuse box and from what i remember it was a red fuse. After replacing that cluster got its lights back...
Old Feb 4, 2008 | 06:08 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
I had mine replaced. It is still having problems. It will dim out to barely visible in the day time.
