squeeking brakes
Old Feb 8, 2008 | 03:09 AM
ssonss1's Avatar
Flying Spur
squeeking brakes
anyone have this problem...only when im coming to a stop...right near when the car has made a full stop it squeeks VERY loud...its the worst right in the morning and happens throughout the day...brakes were changed about 12 months ago..squeeking started about 4 months ago...took it back to the shop and the cleaned the brakes and all that stuff but theyre still doing it..anyone know what it can be???
Old Feb 8, 2008 | 03:17 AM
JRAMGV8's Avatar
1999 C280 Previous / 2008 E350
I spray some of that liquid to get rid of those squeaks...
http://www.partsamerica.com/ProductL...egorycode=3223
http://www.partsamerica.com/ProductD...egoryCode=3223
Squeaks are cause due to break dust and other debris that builds up and that should take care of it.
Old Feb 8, 2008 | 03:38 AM
ssonss1's Avatar
Flying Spur
how often would i have to apply this...and thanks for the quick response
Old Feb 8, 2008 | 03:45 AM
JRAMGV8's Avatar
No problem you're welcome. You can use these product when you wash your car. Apply it before washing it down with water or after.
Old Feb 8, 2008 | 08:33 AM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
this may be true and may work for you but in general,
Squeaks are caused by Rapid vibrations ( harmonics ) generated when your pad touches the rotor an happens at the metal parts where the pad touches the caliper and or brake piston.
Spray will not cure this unless you remove the pad.
This is why MB uses coated shim between these pieces. But you have to make sure that you use brake squeal gel on all parts otherwise they are going to squeal.. Benz cars are notorious for this...
If your rotors are worn, then you are wasting your time because they will somehow manage to start squealing again after a while...
Old Feb 8, 2008 | 12:22 PM
JRAMGV8's Avatar
I appreciate the info but ever since I use that product about a month ago no squeaks..... plus I had the car for 6 months.
Old Feb 8, 2008 | 05:25 PM
Gondon's Avatar
02 S500 Sport
A car wash fixed the squeeks for me
Old Feb 8, 2008 | 06:15 PM
JRAMGV8's Avatar
lol, yup its possible.
Old Feb 9, 2008 | 06:36 AM
ssonss1's Avatar
Flying Spur
thanks all but i think i might just order new front rotars..check my other thread n help me out thanks all
