Trunk will not open
Old Feb 11, 2008 | 06:45 PM
SUHAIL's Avatar
1986 190D 2.5 (W201), 1999 SLK230 (R107), 2000 S500 , 2001 SL500, 2005 G55 Grand edition 327 of 500
Trunk will not open
Without any obvious reason, I cannot open the trunk, not with the keyfob, not with the button on the door (the light on the door button does not come on either) every thing else works with central locking, I am confused any ideas will be helpful. I can open it manually with the key.
Old Feb 11, 2008 | 08:08 PM
platt-deutsch's Avatar
2019 S450
I would guess that the small plastic air piston on the lock mechanism split open. You will hear air hissing when you try to open it if that is the problem. I glued mine back together and it works fine . Not too hard to get to, just take the trunk lid liner off and you should see it..
Old Feb 12, 2008 | 07:04 AM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
I had that problem and it was a fuse blown..dealer fixed it for free.
Old Feb 12, 2008 | 01:24 PM
MILIN1609's Avatar
2001 S430
That is right. Mine is broken excatly the way you said. The dealer wants $375for it. Can't get my mind ready to spend $375 for that little round black plastic box. I will try your glu idea and see. Thanks.
Old Feb 12, 2008 | 01:33 PM
SUHAIL's Avatar
Will try and get to it thanks for the suggestions, I will post my experience
Old Feb 12, 2008 | 06:51 PM
2019 S450
OK.. I used that instant super glue. It is a crappy plastic that not much will stick to.. after I glued it I got a large piece of heat shrink tubing and put that around that broken area.. heated it with a heat gun and it shrunk on there real tight.. been 6 months and still works like new..
Gary
Old Feb 17, 2008 | 02:55 PM
SUHAIL's Avatar
I opened the trunk liner found a lot of plastic things behind it. In short got confused, any way I noticed a "red" tube going into a white box, where should I be looking for the crack.
I pushed on the red tubing and made sure it was secure and wallah it started to work properly.
Will see how long it will work. If anyone can tell me where the crack should be I will be greatful.
Old Feb 17, 2008 | 04:00 PM
2019 S450
There is a black plastic cylinder that is about 1.5 in dia and about 2 in long. It looks like a oversized walnut. It is made in 2 halves.. Where it is joined together is where mine was broken..
Old Feb 18, 2008 | 01:19 AM
SUHAIL's Avatar
I will look for it again thanks, will update when done
Old Feb 18, 2008 | 11:36 AM
zam2000's Avatar
S, GL, Escalade ESV, my shoes
Here's the WIS for the job. Hope it helps.
File Type: pdf
Old Feb 25, 2008 | 01:46 AM
SUHAIL's Avatar
It has been a week now, mine still works fine, just thought I would update you. I guess mine was a loose red hose/pipe. Because that is the only thing that I pushed in gently.
Old Feb 25, 2008 | 01:54 AM
02S430's Avatar
W220 M113K
funny to say this but i have the opposite problem, my trunk pops its self open when ever it wants to, thanks to them looking at my drivers door to see why the soft close stop working
