found some rotors..need opinions
Flying Spur
after doing some searching ive come across the two that are most commonly mentioned on this board( if anyone else has any others i'd appreciate it)
they are for my 2001 s600
1. R1 Concepts-
Front-
http://store.r1concepts.com/Items/It...0-%20120.35049
$212.50
Rear-
http://store.r1concepts.com/Items/It...0-%20120.35050
$200.50
Total R1-$413.00
2.Zimmermann-
Front-
http://catalog.worldpac.com/buymb/02...uymbparts.com/
$135
Rear-
$95
Total Zimmermann-$230
Opinions?![drive](https://mbworld.org/forums/images/smilies/driving.gif)
1. R1 Concepts-
Front-
$212.50
Rear-
$200.50
Total R1-$413.00
2.Zimmermann-
Front-
$135
Rear-
$95
Opinions?
1 Post
W220 M113K
Cross-drilled: Holes are drilled through the rotor to dissipate heat. Cross drilling is very effective for heat dissipation. It will prolong the life to the pads, rotors and improve stopping power. It also shed off water under-wet driving condition.
Slotted: A line cut on the surface of the rotors to dissipate heat and increase bite. Slotted rotors will bring up the operation temperature of the braking components much faster over cross-drilled, yet it dissipates the heat at the same time. The added bite will reduce the stopping distance. Slotted rotor does not scarify the structural integrity of the rotor.
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
if that was the case why does AMG use them and they are OE on the front of our S-Classes
THe zimmerman rotors are drilled just like the OEM... They are better priced than the OEM by about 25 bucks. per rotor. the rear prices are about half. AND thay are not drilled either OEM or Zimmerman.
Point. Just because AMG uses them Does't mean they stop better.. There is more to AMG brakes than just rotors. They are much larger than ours and they have much larger calipers than ours.. All of this combined is what makes them stop "better" is what helps them stop better.
I agree Drilled AND slotted is the way t go if that was reasonable possible, but FWTW I'd just swap with OEM equvivalent unless I am doing some major brake upgrade...
I wouldn't consider going from a drilled rotor to a drilled and slotted rotor a MAJOR brake upgrade. LArger rotors, and calipers, THEN its a brake upgrade an makes sense to spend the extra on D/S rotors. BUt it's kinda pointless to pay double if you are just getting about the same performance.
BTW. THose are some bad *** wheels......
02 S500 Sport
I will be in a few weeks.. I'll let you know what I think but I'm sure i'll be happier than I am now....I have 4 and a new ( better )fuel filter in my kart from autohauz Az... I hope I didnt miss the free shipping....
02S430,
I like your wheels a lot. They go well with your car color. are those Lm5's?
I'm not doing big brakes eithr but I am going to change my calipers to red in a few weeks to go with my New look. Possibly some MandrusMillenium wheels but I kinda want to keep the double spoke 20's and see how they look after I'm done.
1 Post
W220 M113K
my06clk,
no there Boze wheels, i took the pic off there website as im waiting for them to arrive, but once on they will look actually like that pic,( i have the same darkness tint no sport body and silver in color) i went with 245/35/20 based on several of those web calculators to keep the wheels and speedo accurate http://www.alloywheels.com/tyrecalc.asp
2005 SL500, Black on Stone
I am running Zimmerman Rotors on an 02 S430. I replaced the original rotors at 36k miles on all 4 wheels with Zimmermans.
I replaced the original pads on all 4 wheels with Akebono pads. No more brake dust, and I mean NO DUST at all, which is fantastic if you like clean wheels.
So far (6k miles later), the Zimmermans seem fine. The Akebonos are slighly less "grabby" than the stock pads and require a slight bit more pressure to stop the car then the stock pads.
2000 ML430
I agree with Flong but I think you both are saying the same thing.
Slotting and drilling accomplish two seperate objectives (per Brembo engineer I spoke with last year). Drilled is OK for street, slotted is better for track use. At least that's what he told me. The Brembo site itself did not weigh in either way.
From Brembo:
What are the advantages of drilled and slotted discs?
The main advantages of drilled and slotted discs are the same: increased brake "bite", and a continuous refreshing of the brake pad surface. Drilled discs have the additional advantage of being lighter and running cooler. However, there are certain pad materials that should not be used with a drilled disc.
I installed zimmermanns all the way around n my car the other day..
The car brakes nice.. the rotors are fine,, I was glad to get that section of my
car back up to specs... i had a lot of issues with my old rotors but they lasted to 80K so no complaints there..
Hopefully the zimms last that long.. I sure like the way those brand new
rotors look!! I treated her to a new set of Nittos also so I'm ridin' good right now.
Flying Spur
I bought bendix semi metallic pads from Autozone or Advanced i forgot. I paid under a hundred bick foe both sets..I'm happy ith them sthey stop the same or better that OEM minus the dusting.. and I used some high temp permatex for my squeeky rears it works nicely so far.
Flying Spur
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
ok i was just ordering the rotors online...my prices were wrong..its 135 per rotor for the front and 95 per rotor for the rear...what price did you get them for and from where...if this is the actual price im just going to go with the r1 concept drilled and slotted........help!![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
Try AutohauzAz my total was 271.00 for all 4 shipped.
Flying Spur
thanks for the help...i went with the r1 concept premium rotors...drilled and slotted front and rear with axxis pads (no more cleaning the wheels every 2 days
) total came out to 570$ shipped...ill post my review once they get on
I have ordered a pair of R1 cross drilled rotors for the rear, but I have returned them and put my stocks back on. The major difference between slotted and cross drilled is the fact that slotted cleans the surface constantly as more pressure is added. Also I'm sure everyone is familiar with you get what you pay for.
Scientifically some of this so called "cross drilled" rotors can be unsafe. Most companys start with a "blank disk" and drill the holes threw them to create the cross drilled look. Once metal is cooled and you drill holes through it you create microscopic cracks, which overtime and heavy usage manifest themselves into large cracks in the rotor. Thats why I stick with Brembo, they make their holes in their rotors in the molten process before it has a chance to completely cool. This reduces cracks, and makes the disks stronger.
If you don't believe me I can send u a bill of what it cost when you use those cheaper type of rotors and try to stop your car from 120+ and getting off an exit to a red light. (Somebody was looking out for me). Just something to keep in mind....if you want to know what happens when a rotor completely fractures under high speed, go to youtube. I'm pretty sure they have something interesting.
