Electric Steering Wheel Position Adjuster
Old May 29, 2008 | 06:07 AM
buycobalt's Avatar
2003 SL55 AMG
Question Electric Steering Wheel Position Adjuster
Hi,
My steering wheel adjuster has stopped moving down all other directions work fine. Has anyone else had a similar problem? Do I need to buy a new motor or switch? Any idea of cost? Thanks in advance!
Old May 29, 2008 | 09:16 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
See post #14 at http://www.benzworld.org/forums/w220...ml#post2216730.
Before you try the reset procedure for the steering column, which will require running the wheel full up, you might want to drive to the dealership in case the reset was not the problem. The full up position could make driving difficult for some.
