Idle problem - Plugs vs mounts
Any thoughts?
Jeff
Any thoughts?
Jeff
When these mounts collapse, the olnly this you will get is the vibrations at fist. If you et then go, the rubber will break and you will have nothing supporting your engine to the frame so it will start moving when you accelerate causing loss of torque and possible damaging the tranmission mount if it isn't already..
This is not something you want to let go forever...I will do mine in a few weeks and post pics of the process so you will be able to see if this is something you want to do yourself.
As far as the vibration question,
NOPE. No at all..
THat is another problem..YOU need to re-evaluate your wheel situation.. Just because it does it on both sets does not means hat there isn't issue with both sets..
Speed dependent vibration 99% of the time is wheel/Tire related.
