coolant temperature sender
Old Jul 28, 2008 | 10:57 AM
Crankin's Avatar
2000 S500 Brilliant Silver, 1990 BMW 735iL, 1971 Pontiac Trans Am 455 HO, 1976 Pontiac Formula 400
My S500 is showing a low coolant message on the dash display, even after I have topped it off ( which took very little coolant).
My coolant temp. gauge reading has been normal, so I think it is the sender. Is this a DIY easy to do, and where is the sender located?
Old Jul 28, 2008 | 11:17 AM
whoover's Avatar
'19 E63S sedan
It sounds like you want the coolant level sensor, not the coolant temperator sensor. If so, it's on the coolant expansion tank. It's an easy job.
You should also know that sometimes a bad windshield washer fluid level sensor masquerades as a bad coolant level sensor. They are wired together and either can go bad in a way to mimic the other. You might want to replace both.
Old Jul 29, 2008 | 11:12 AM
Crankin's Avatar
Thanks, Whoover. My windshield washer level warning comes on too, so I will replace both.
