NHTSA - AIRMATIC failures
NHTSA Action Number: PE07042
Campaign Number:
Vehicle/Equipment Make: MERCEDES BENZ
Vehicle/Eqipment Model: S CLASS
Model Year: 2000
Mfg Component Code: SUSPENSION:FRONT:SPRINGS:AIR SUSPENSION SYSTEM
Manufacturer: MERCEDES-BENZ USA, LLC.
Date Opened: 08/14/2007
Date Closed:
Subject: AIR SUSPENSION SYSTEM FAILURE
copy paste from:
http://www.aboutautomobile.com/inves...EDES+BENZ/SL55
The subject s-class vehicles contain a compressed air suspension system that uses air struts on each of the four wheels in lieu of traditional springs and shock absorbers.These air struts use compressed air to support the weight of the vehicle and control ride height.In the event of the loss of air from the system, an alert will flash on the instrument cluster warning the driver to either drive carefully or to stop the vehicle.The vehicle ride height can be reduced by as much as 105 mm below normal ride height before the full load of the vehicle for that wheel comes to rest on a steel rod, with a rubber stop on the end, located in the shock absorber.This rest-stop condition is designed such that there is no impact on vehicle control.Mercedes-benz (mbusa) supplied video showing a vehicle in this condition operating under several different situations including evasive maneuvers demonstrating the ability of the vehicle to be controlled effectively with a ride height reduced to the minimum.Only those complaints to odi and mbusa that alleged a steering interference during a reduced ride height condition were counted in this resume failure report.Some complaints alleged that with a reduced ride height and a "stop now" warning message there was a rubbing noise when turning, but the ability to steer the vehicle was not compromised.A sampling of warranty claims submitted by mbusa did not reveal any indicating a loss of control due to an airmatic system failure.There was one crash reported by mbusa to odi but the information available indicated that it related to suspension systems and it was not possible to verify that the incident was related to an airmatic system failure. Further use of agency resources in this matter does not appear to be warranted.The agency will continue to monitor complaints and other information relating to the alleged defect in the subject vehicles and will take further action in the future if warranted.This preliminary evaluation is closed.
