Can I buy a 07 and up SmartKey and use on my 03 S55 !
When I got my 03 S55 used, it only came with one SmartKey, now I am thinking to get another Smartkey for the car, Can I get the newer (07 and up) Smartkey that come with chrome cover on two side and reprogram by dealer ?? if yes, how much is the Smarkey going for? $250 ?? $300?? Anyone did get the newer key for their W220?? thanks
You should have the service department code the new key as a replacement for the missing one. If you don't the EIS will treat it as an additional (third) key. The difference is that two keys have their own memory settings. That way, using key-dependent memory, two people can have different default (M1) settings for seat and mirror triggered only by the key they use. Of course, each can program their own different memory settings as well. It works very well. But a third key doesn't have any memory slots in the EIS.
S, GL, Escalade ESV, my shoes
It cost $180 each. Try Mercedes of South Bay.
1 Post
2008 S550 designo
I decided not to try and get the newer one since I have Keyless Go - I never see the key except when I'm putting it in my pocket.
Post if you find otherwise - it's good information for the board.
trey
I just went through the process of getting a new key for my S55 w/Keyless Go two weeks ago and I could not get the chrome key. I spoke with the parts guys at length and they called MB USA and no dice. Sad, Chrome is SHINY
Did they say whats the reason?, since I never use my keyless go card !
2000 S430
https://mbworld.org/forums/s-class-w220/208971-new-mercedes-key.html
though that site to order from seems to no longer be a benz dealership
1 Post
2008 S550 designo
https://mbworld.org/forums/showthread.php?t=208971
trey
If you have the older style of keyless go (2004 or older) you can get the new chrome key, it'll work like your black one since your keyless go is a card-key.
2005 or newer cars (with keyless go) the key itself act as a keyless go and standard key so you cannot get chrome key. You can infact get the chrome key for 2005+ car but it'll work in ignition only and keyless go function will not work with chrome key.
1 Post
2008 S550 designo
I checked with my parts guy again and he said you can get chrome for every model with Keyless Go EXCEPT S and SL. He does not know why.
trey
Forgive my ignorance as I'm a new MB owner, but is the only advantage to having the '07 and up smart key the "chrome covers" on both sides.....or are there different functions as well?
2005 S500 4Matic
On the down side, it is larger and heavier.
