2nd S Flooded This week! S Owners Keep your Drains Clean!!!
#77
I just had this happen to me, luckily not too much water got in before I noticed it.
#78
2005 S500 4-Matic, 1978 450SL
I never said he should seek double reimbursement for damages; you introduced that.
If he does not contest the denial of claim, neither the hotel's insurer not his own company will do anything about it. It is up to him to point out - best if to both - that he has damages that are not covered.
3) Don't impugn my motives, Richie999. I have suggested that he can recover the entire amount of his damages. They are significant. Laying down and leaving everything in the hands of two insurers, with no action on his part, will causes him unnecessary loss.
#79
2000 E320 2009 E550
WATER DAMAGE
To recover his out-of-pocket expenses not covered by his own policy, of course. Think! It is inherent in what I said.
I recommended that he contest the hotel insurer's denial of claim. This is done in an appeal to the insurance company, with the process for appealing ordinarily pointed out in the document denying all or part of a claim. He would of course work through his own insurance company, which is clearly already involved; and he can do so through BOTH - a matter which he clearly understands, since he discusses subrogation. He has pointed out two additional options, involving legal action in court. I have not recommended legal action in court at this point, despite both being available options. His contest of the denial is to the company that denied it, and to his own insurance company.
They have to know of the damages that are not being covered. He has to tell them.
"...Except for what is not covered by your insurer" - exactly what is different from what I said?
I know it is best to work with my carrier during the subrogation. The third party carrier may continue to deny the claim or agreed to settle for a lesser amount to avoid going to court. If the amount very small some insurance carrier will not subrogate because of the cost of filing a law suit.
I have made my carrier aware of all the my out of pocket expenses and they are aware of the amount they have paid the dealer.
I think it is a dead end with the third party carrier after all the appeals. Once an attorney is introduced in the process by my carrier I should see some type of movement by the third party carrier.
#80
2000 E320 2009 E550
Water Damage
Despite the damage originating from a different cause, it is likely to be the same as the damage caused by the plugged drain holes. Your dealer should check the SAMs and replace them if necessary. With functioning SAMs you should be OK electrically.
Your oil should also be checked for water. It is likely the water you saw discharged was in the muffler, and perhaps the CATs - but it could also have gotten into the crankcase.
You may have been much better off if the hotel manager had left your car alone, and let you have it towed.
The vehicle has been in the shop for over two months withou any estimate on the completion time most of the time was used to rewire the vehicle.
The dashboard was removed earlier this week.
I asked the dealer about the oil and replacing the battery. He said they should be okay. He said they will completely check the vehicle once the wiring is completed. The dealer is estimating another two to three weeks before the vehicle will be completely repaired.
The dealer services two other brands and Mercedes-Benz. I am not sure what portion of the shop is limited to MB.
#81
#83
Payment for Future Water Damage: MBUSA will pay for repairs due to water damage incurred as a result of a clogged reed valve in Class Vehicles after the Effective Date of the Settlement, but prior to the expiration of eighteen (18) months from the Effective Date of the Settlement or up to 100,000 miles on the vehicle’s odometer, whichever occurs first, provided that: the owner or lessee obtained regular “A” or “B” service at an authorized Mercedes-Benz dealer during the period between Final Approval of the Settlement and the onset of water damage; and all water damage repairs are performed at an authorized Mercedes-Benz dealer. MBUSA will notify authorized dealers regarding the settlement and this provision, and will compensate dealers directly for repairs (parts and labor) performed pursuant to the Settlement Agreement, including installation of a secondary drain valve pursuant to MBUSA Dealer Technical Bulletin (“DTB”) P-B-83.10/75.
Settlement Date: June 16, 2010
Does this mean we are still eligible?
http://www.reedvalvesettlement.com/faq.html
I've been doing my A service in an Independent any way I can play this off?
I need to get my blower motor/regulator on AC replaced.
#84
Just get service done at MB now, and go back a bit later to get the blower fixed....
The Settlement date was June 16 2010 so its reasonable time for you get a service now. The services did not need to be done at MB prior to settlement date
#85
Hi everyone,
I have the same problem, the carpets at the rear are soaked, but it seems that this happens when I top up the water in the car. When I top it up the carpets get drenched with water. And I get an error on the dash to refill water every 2 days from full. Any ideas? The mechanic checked and couldn't find a leak strangly enough
#86
I'm curious. What do you mean by "top up the water"? Adding antifreeze/water, adding windshield washer/water or something else? None of the systems are directly interconnected but if its the engine cooling system, I can see how a leak in the interior heater box could leak into the cars cabin area. Were exactly does the carpet get drenched?
#87
Adding anti freeze/water... The carpets get drenched on both sides at rear.
The water is coming through the grills at the bottom. The trays gets full of water and then starts going over the top.
#88
take a picture of where you are adding the water. You wouldnt happen to be adding the water into the black box with the plastic waffle covering , by the windshield wipers, are you?
#90
Do you have the rear seat heater configuration? Any idea on quantity, ie does it look like the same amount of water is soaking the carpet as you are putting in? Does the water in the soaked carpet have glycol in it as well (I would assume so but check anyways if you don't know. See if it is sweet tasting)
#92
2000 E320 2009 E550
FLOOD WIRING HARNESS
The total cost was $13,815.00. The wiring harness was replaced, replaced front seat frames, replaced front seat control units, replaced seat heater control and replaced airmatic compressor.
There were no problems with the vehicle on the drive back home.
The dealer was a multiple dealership servicing three different manufacturers. There may have been only three of four MB mechanic in the dealership. There may have been about twenty bays in the shop servicing all three manufacturers.
In the future if I am only a couple of hundred miles from home. I would consider towing the vehicle to a local large dealer or making sure the dealer is AAA approved.
I will have to wait for my insurance carrier to subrogate out any out of pocket expenses.
#93
The second has already been identified as SAM (not by me) and the third is a mystery. You would typically expect in there the unit that controls the phone and the unit to control hands free phone operation. The latter can also be a Linguatronic module. The device shown is neither of these.
#94
2000 E320 2009 E550
The first picture shows the seat controller - it delivers compressed air to various parts of the seat to adjust lumbar and other settings.
#95
You may have a missing or leaking headlight washer nozzle. It's my guess that water can migrate from the headlight area into the passenger compartment. I have simply capped my headlight washer exit nozzle at the refill tank. It comes out very easily.
#96
Well, today I removed some components from the car from under the rear passenger right seat.
I removed the grey square component which is attached to it's metal frame housing still, along with a small white clear plastic box, all connectors removed and left in car.
This grey square component has connectors for heated seats and one going to the CAN?
There are also a couple of boxes attached to the underside of the metal frame.
Picture below, please can someone name these components and what they do :-
Attachment 145589
I also removed this part which I think is the rear SAM and took it apart from the rear fuse box (which is left in the car with the 2 million wires).
Picture below, please can someone confirm this component and what it does (hope the lights as mentioned before)
Attachment 145590
And finally this small solid metal looking component with BOSCH labelled on it, this was the most wet and the connectors were dripping when I removed it.
Picture below, please can someone name this component and what is does :
Attachment 145588
I have left all the wiring in the car along with the rear fuse box, to dry away from the base of the seat area and left lots of absorbant towelling to get any remaining water and to hopefully dry out some of the wet wiring.
If drying these out does not work, at least I know I can change the part if need be, but which one of the above components does the lights related to, paticurlarly the registration lights?
I have been told the rear SAM which I think is the part I detached from under the rear fuse box in the second picture?
Thanks in advance.
Attachment 145589
Attachment 145590
Attachment 145588
Thanks in advance.
#97
2000 E320 2009 E550
Water damage to vehicle
All the carpet and floor mats were remove together with any damage parts below the floorboard. The wiring harness and all it components were replaced. The seat motors and heaters were replaced.
The only additional service that was required about a month later was the replacement of the airmatic module. I started receiving a malfunction notice on the displayed. I was not sure if it was warranty work or from the floor. The factory representative came out said it was not related to a part failure and was not covered. The insurance carrier came out took some pictures of the module that showed water damage and approved the additional repairs.
I am not sure how well you can dry any parts out that are still attached to the vehicle. I drop my vehicle to Death Valley for a few days the temperature was over 100 everyday. The water from the initial flood was not dried out. I understand that the water just travels along the wiring or other parts like a wick.
#98
Well my issue was resolved last week.
I took out the blower motor and it turns out it was seized and had rust on the axles which was preventing the fans from spinning. Put WD-40 on the axels and spun the fan loose.
Started right up like a champ..I was expecting all the electric internals to be fried..
#99
2000 E320 2009 E550
WATER DAMAGE TO VEHICLE
I was surprise of the amount of damage that can be sustained to a vehicle pasting through a small amount of water or being flooded in a few inches of water. I take extra caution when driving in the rain and where I park my vehicle.
#100
The problem with our cars is that you don't need to drive through water, simply being out in the rain or even going through a car wash can cause the interior flooding!!
