2nd S Flooded This week! S Owners Keep your Drains Clean!!!
It is not uncommon to find flooding in the boot. This can get in thru leaks around the taillight housing, thru or over the lid gasket, around the rear window seal and thru loose or missing rubber plugs in the sides of the recesses on each side. Leaks into the left rear fender well will destroy the electronic and electrical devices installed there.
Regarding rear seals, i really cant see how can such a large amount of water creep in from the lights fittings etc. Very odd!!
water under the rear seat comes from the reed valve In the engine compartment clogging , and water that travels front to back seat under the carpeting in the electrical trough in the floor pan
I thought i should put this here, in case it helps anyone else.
The water ingress was from two small screws in the side of the boot (not the lid itself). These were just failed screws.... All sorted now! Thanks everyone for the help.
Haris
