Check engine light code P0410
Old Nov 23, 2008 | 02:03 PM
Benz5656's Avatar
SL500
Anyone know what this is? It says Secondary Air Injection System Malfunction? Is this serious?
Old Nov 23, 2008 | 06:24 PM
benz_addict's Avatar
V12TT
http://freeautomechanic.blogspot.com...uble-code.html
http://www.obd-codes.com/p0410
just clear your light and see if it comes back if it does then you have a problem.
Old Nov 23, 2008 | 08:15 PM
Benz5656's Avatar
SL500
Hey I really appreciate it
Old Nov 23, 2008 | 08:53 PM
ohlord's Avatar
When you
start the car in the morning ,listen for the sec air pump to be running.If it is then check all vac lines associated with it.If the pump is not running you will not pass smog and the cats will take longer to fire up,but it won't affect performance.
Then clear the codeand see if it comes back.
