Brakes squeal like a pig all the time...
I took the pads out, applied a spray-on lubricant for pads and assembled. Fine for about 10 stops then the sounds return.
About two months with the new brakes I took everything apart, cleaned it and lubricated everything with anti-squeal paste. Also coated the rotors with special metalic coating designed to stop brake noise.
Assembled everything, drove the car... it was fine for about 10 stops then the sounds crept in again.
I'm out of ideas and just honestly annoyed.
High-performance brake system (S 65 AMG only)
The high-performance brake system is designed to operate under the extremely high operating demands required to accommodate the performance capabilities of the vehicle. The brakes may produce a squeaking-type noise depending on the
vehicle speed
brake force applied
ambient conditions, e.g. temperature and humidity
SLR drivers report their cars being confused with ambulances because the squealing is so loud.
My advice is to train yourself to be proud of your loud brakes.
I hate the squeeling too... Oxygen, put the stereo up loud enough so you don't hear it. Sometimes if you slam the brakes hard enough, it gets rid of the dust thats hidden/built up that causes the squeel.
Don't they make anti squeel oil? Maybe better than the spray?
vehicle speed
brake force applied
So you're saying your car exhibits the same behavior?
I wish my brakes squeaked. Anybody know how to make them squeak?
Get PLENTY of heat in the brakes and the squealing should stop or be diminished significantly!
Roll that S600 like a driver and not a cruiser SON!
"DIS IS MY UHH S65 UHHH UMMM UHHHH S55 AMG"
you can apply a but if high temp grease between the pins and the spring that will help a lot in that area.. I also oated my spacers between the pad and between the calipers with high temp silicone ( orange RTV ) let it set and I don;t squeal at all anymore.
I bought new brake hardware just in case but never installed it because I have good results.. That was early last year sometime and I haven;t had any issues since.
new brake pads and old rotors causes the squeeking. i think your suppose to replace them at ecxactly the same time.
i know what you mean with the squeekign that shat is def embarrasing...too bad i dont have that problem
jp
vehicle speed
brake force applied
Lately I've been getting on the brakes a little harder, they make some noise initially but after a few red lights they are warmed up and make no noise at all.
Thanks for the information.
I've seen some of your passengers so maybe it's not the brakes that are squealing SON!
