no sound from command system
Old Jan 30, 2009 | 04:06 AM
frk203's Avatar
1985 500sec, 1991 500sel, 02 clk430
the battery died a couple weeks ago in my car,
now no sound comes from the radio/navigation, the system turns on and i everything seems to work find except no sounds comes out, also when i switch to CD it says "cd changer not detected" or something like that.
i checked all the fuses under the hood and under the rear seat, specificly fuse 61 and 66 which are stated as the ones for the radio and CD changer, but all fuses are fine, so now im kind of lost and looking for some help
Old Jan 30, 2009 | 04:57 PM
scarybary's Avatar
2004 S600
WHAT YEAR AND MODEL DO YOU HAVE. MY 2004 S600 HAD A SIMILAR PROBLEM AND IT TURNED OUT TO BE THE BOSE AMP WHICH I COULD NOT GET REPAIRED BUT HAD TO REPLACE AT $1600 PLUS.
Old Jan 30, 2009 | 05:35 PM
frk203's Avatar
wow 1600+
sorry i forgot to put the year and model, the car is a 2000 s430.
is there a way to test the amp? also do you know where its located?
im wondering if its possible to put a different kind of amp if it is the one that causing the problem, cause honestly i just spent ~$550 to replace the front left strut (got a rebuilt one from ebay) and i dont have too much money to spend.
Old Jan 30, 2009 | 08:47 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Check the amp itself for any accessible internal fuses (see the phone bulletin for your car at http://home.earthlink.net/~phdwebsite/comand_manual.htm - for the amp location; use the '01 bulletin). Also check that the fiber optic leads (orange "wires") for the amp are firmly seated. Also check the fiber optic leads for the CDC.
A Google search will get you a number of places that claim they can fix Bose amps for the Benz.
Old Jan 31, 2009 | 06:46 AM
frk203's Avatar
thanks for the help
i checked the fuse on the amp and its fine, i still havent checked the amp wires yet, i read somewhere that since its a fiber optic system if one part goes bad the whole sound network wont work. so since its displaying "no cd changer" i thought i test that first.
the guy with the post also said that there is some king of a couple that i can use for the fiber optic cables that will let the system work without the cd changer so ill probebly try that and see
Old Jan 31, 2009 | 07:45 AM
blas0827's Avatar
none
you need a amp sorry to tell you bud
Old Jan 31, 2009 | 09:37 AM
Johnboyps's Avatar
05 S430 & 99 SL500
I had the same problem with my 05 S430. The dealer installed some updates in the command and it is fine now. My car has the Sirus radio and cellphone and there were updates required. It was updated about a year ago and its still fine.
Old Jan 31, 2009 | 11:58 AM
4matic's Avatar
04 S430 4Matic/03 Ml 320/ 98' E320 4matic/ 73' slc 450/ 05 cherokee
Post
well how do you know he doesnt need an update
Old Feb 1, 2009 | 12:23 AM
ejack's Avatar
2001 Mercedes s500 amg sport
I had a similar problem with my S500. The problem was ultimately traced to a
faulty CD player. Once it was physically removed from the fiber optic loop
the sound returned. The error message seems to point to the CD player.
I would have a specialist check the continuity of the fiber optics cabling in
the trunk of the vehicle, or whatever he thinks is the most probable
cause of the problem.
Good luck.
Old Feb 1, 2009 | 01:41 PM
Skylaw's Avatar
If anything is removed from the fiber optic loop and not replaced, a fiber optic jumper must be installed to close the loop. A dealershio should have them.
Old Feb 2, 2009 | 05:12 AM
frk203's Avatar
im gona go to the dealer today or tuesday and get that then put in eliminating the cd changer and see if that fixes the problem (keeps finger crossed)
does anyone know how much the jumper should cost?
Old Feb 2, 2009 | 05:42 AM
frk203's Avatar
also another off topic question does anyone know how i can go to the diagnostic mode in the command system?
i read a couple different post and each one list a different way but i dont know which is the right one for my car with the older command system (its a 2000)
i tired the mute+1+3 but it didnt seem to work
i also tried call+ok and it also didnt work
Old Feb 6, 2009 | 01:58 PM
frk203's Avatar
i finally found out how to get to the diagnostic mode!
i had to go to tape mode then press Mute +1 +3 all together.
anyway im getting this code:
N1112 Lost Communication between D2B master and other device
also when i do the D2B diagnostic, on the result none of the result is checked
does this mean its a problem with the amp/amp connection or could it be the cd changer since its the first thing on the network?
Old Feb 6, 2009 | 03:56 PM
Skylaw's Avatar
Post #10 explains the cause. Your fiber optic loop is open. There is either a component missing, a faulty component, or a loose or broken connection at one of the components.
Old Feb 6, 2009 | 06:22 PM
frk203's Avatar
i went to the dealer today and bought the fiber optic loop thing, it was about $5 and some changer.
i found this site that tells me how to install this loop thing:
http://www.carstereohelp.com/mercedesFiberOptic.htm
hopefully ill have time to work on it tonight.
thanks for the help
Old Feb 6, 2009 | 09:36 PM
ohlord's Avatar
Relating one issue
the dead battery and the subsequent failure of the nav unit,have you pulled the unit and removed the fuse and checked it then disconnect it from the harness and rehook it and power it up.It may just need to be woken up.
Old Feb 9, 2009 | 06:08 PM
MSackson's Avatar
00 S500 & 2008 E350 Wagon
I replaced my Command unit in my 2000 S500. I have all the various parts, if you need something, let me know. Everything is negotiable. I have picture if you want to see them.
Mark
Old Apr 6, 2009 | 03:43 PM
frk203's Avatar
i tried resetting it and a bunch of other stuff but nothing worked, im probebly just going to take it to a mercedes specialist i know sometime next week.
Old Apr 7, 2009 | 02:36 PM
cameraman123's Avatar
2000 Mercedes Benz S500 Designo
"NO CDC" message could simply mean that one of the components on the loop is out. You can bypass each on to test with a $6.00 Bypass coupler from the dealer. REAL EASY, my 00 s500 had the same thing happen
Old Jan 12, 2010 | 12:51 PM
Benz915's Avatar
2006 ML500
Hey frk203, did you ever find the problem with your command??
Old Jan 12, 2010 | 02:39 PM
malahhaor's Avatar
06 Carrera4
I had exact same issue in my CLK and it was the Amp, i had to fight with the dealler because he kept telling me you will need a new radio and i was convinced it was the amp. New radio was still giving same issues, not till they replaced the amp everything started working.
Old Jan 13, 2016 | 01:43 PM
Cmedlin4040's Avatar
mercedes clk500
amp location
does anyone know amp location for 2005 clk500 mercedes?? no sound coming thru
Old Jan 13, 2016 | 01:57 PM
mercedes clk500
Mark
Can you tell me where the amp is located on my 2005 clk500 ? i think its the amp and do you have one? thx
