Cruise Control Won't Set ... ?
i was thinking that the computer was having difficulty reconciling the different
rotation speeds between front and rear but this doesn't seem likely given your
specs. cruise module on the blink? had dealer looked at it yet?
I recently changed my wheels to a 19" and ever since then my cruise won't set above 70km. If I try to set it above 70km the cruise bars in the instrument cluster flashe for a few secs then stop. I have the alignment done however still not solved. PLEASE ADVISE
I had some other problem to reset the whole system i removed the battery once i reached my office. In afternoon i put the battery on and start driving. when i tried to set cruise on 140 KMH the same problem occurred.
Remedy
Switch the engine. Turn on and off the ignition three times, remember no start. and system reset to normal. I think you have to do this with hard reset every time. As i have to do it.
Regards
Remedy
Regards
Step 1: "Switch the engine"? Do you mean switch it on or off?
Step 2: "Turn on and off the ignition three times, remember no start." I understand this part.
Do you mean to start the process after leaving the battery disconnected for a short time and then reconnecting it or can you start with Step 1 without disconnecting the battery?
Thank you!
