Shaving offset
Old Mar 22, 2009 | 01:34 AM
Arlen777's Avatar
2002 Mercedes S 430(GONE), 2001 E320(GONE), 2007 S550(GONE), 2009 BMW X6(GONE), 2014 S550
Shaving offset
i was wondering if it possible to shave wheel offset and how dangerous it could be to drive on shaved wheels
Old Mar 22, 2009 | 03:35 AM
cheez80's Avatar
it is possible. i know this 'cause my set of MAE's were 26mm more aggressive than i thought (the seller screwed up when posting offsets - they're actually ET-13, not ET13!) and the wheel shop is shaving them down 15mm for me. it depends on the pad design and depth, so not all wheels can be shaved very far. most shops will only do 3-5mm for fear of liability down the road.
with all the risks involved, perhaps fender modifications would be an easier route? i can't mod my fenders anymore (they're already rolled and pulled to within an inch of their respective lives) without causing weird deformities, which is why i went down the path of shaving instead of modding the fender.
anyway, whichever way you decide, good luck!
EDIT: oh yeah, just to clarify -- these wheels aren't going on a mercedes of any sort. wouldn't it be cool if a w220 could take something sized 18x11.5 ET2 with just a fender roll and pull?
Old Mar 22, 2009 | 10:06 AM
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
Dude is very important to go with the best wheels and tires for your car , so don't screw up you get what you pay for .
Old Mar 22, 2009 | 11:37 AM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
I guess anything is possible. Question should be "Is it practical?".
Old Mar 22, 2009 | 12:23 PM
ohlord's Avatar
Buy the correct
rims.A hubcentric spacer is fine if you need to push a rim out,shaving material to move it in?Do you really want to see a tire and rim combo rolling past you when they let go? 25mm is about an inch,so if you need to move the rims in that much to make them fit the wheel wells take a look at the rim and you decide if it is safe
Old Mar 22, 2009 | 01:14 PM
GARY JAVO's Avatar
2003 S-600
Doesn't sound like a good idea. I had to remove a slight (1-2mm) amount of material from the inside of my wheel spokes to have proper caliper clearance in the rear (4" lips and w220's don't easily go together), but removing that kind of material from the wheels seems over the top. That's JMHO.
Good luck.
Old Mar 22, 2009 | 06:48 PM
Arlen777's Avatar
C i wanted to pull the fenders but yesterday found out that my wheels rub some metal thingy which is under the fender and close to the front
Old Mar 22, 2009 | 07:32 PM
Benz5656's Avatar
SL500
On the rears I am running a 20X11in wheel with a 5 inch lip. I had to do all the above. Be sure to do proper research when shaving wheels. I actually had mine machined, to keep the proper balance. (A problem you can have if not done properly) Lastly, I had an 1/8inch shaved off the caliper itself, then I had them powder coated. (That was a little extreme, but worth it when you see how deep the lip is) I have taken corners at well over 90mph with no rub no flex, and no excessive heat from the rim being so close to the caliper.
Old Mar 22, 2009 | 11:30 PM
Arlen777's Avatar
so i guess it also depends on wheel brand, if its good quality so it could be shaved with no problem, because i just need mine shaved about 5 mm max so it wont rub front arcs
Old Mar 24, 2009 | 11:09 AM
Benz5656's Avatar
SL500
Yeah and be sure to contact the makers of the wheel, not the seller. They are the only ones who know the true strength of the wheel and how much material can be safely removed. Here are some pics
Attached Thumbnails Shaving offset-0_image_063.jpg   Shaving offset-0_image_064.jpg
Old Mar 25, 2009 | 01:44 AM
Arlen777's Avatar
Thanks man, BTW on ur pics brakes almost hit ur wheels, how much did u shave them?
Old Mar 26, 2009 | 12:17 AM
Benz5656's Avatar
SL500
To be honest with you I can't tell you, I know its an 1/8 inch off the caliper itself and close to a 1/4 inch off the rim. U can only put about 3 peices paper between them. lol
( O yeah when two objects pass by each other that close and that fast they "can" generate heat even if they don't touch, so make sure whomever does your work makes sure both surfaces are smooth so air can flow through)
Old Mar 26, 2009 | 02:25 PM
Arlen777's Avatar
Wait, So i can shave calipers also??
Old Mar 26, 2009 | 02:31 PM
Benz5656's Avatar
SL500
Yes, I do. MB does make 2 types of rear calipers for the W220 one has a smaller piston reserve (which I shaved down). You can order this part and the rim will fit closer, But I didn't have any issues with mine, and I did this in June of 2008. I drive hard and haven't had any issues.
