I Need Your Opinion Guys!Dealer Says I Need Many Repairs!!
Old Apr 21, 2009 | 06:45 PM
S500 Man's Avatar
White S63 AMG W/Designo Interior
Unhappy I Need Your Opinion Guys!Dealer Says I Need Many Repairs!!
List Of Items Needed To Be Replaced Please Help Me Fill In Blanks And How Hard It Is To DIY:
Winshield Wiper Blades Torn $___
Spark Plug And Fuel Filter Replacement $______ ALSO What kind of spark plugs should i buy????
Front Struts Relief Valve Chamber Seals/Valves Leaking Air $______________
Right Outer Tie Rod and Left Inner $260.00 REPLACED.
Front Left Headlight Washer Assembly Cracked $_________
Old Apr 21, 2009 | 07:08 PM
S500 Man's Avatar
bump
Old Apr 21, 2009 | 08:00 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
23 minutes between posts. Com'on. You got to give it more time. Maybe you ought to ask your butler.
BTW, replacing windshield wiper blades.........................
Old Apr 21, 2009 | 08:30 PM
Quadcammer's Avatar
96 and 08 911 turbos
Right Outer Tie Rod $______
Left Inner Tie Rod $______
Wiper blades are like $60 or so, and replacement takes 14 seconds.
Fuel filter is about $50 i believe, and should take about an hour
Plugs are like $80-120 and about 2.5-3 hours if you know what your doing.'
Not sure if that can be repaired. buy arnott remans for $400 and install takes about 45 min to 1 hour.
Outer tierod is about $120, inner is about 70. Outer is a piece of cake, inner, not sure about. You will need an alignment.
I seem to recall the headlight washers being about $75 for the unit. shouldn't take too long to replace.
all prices and times are estimates based on a good working knowledge of the 220.
Old Apr 22, 2009 | 12:25 AM
S500 Man's Avatar
thanks!bought some denso ik16 spark plugs for 135.00 they had 2 brand fuel filters one purolator for $50 the other beck/arnley for 100.00 will repair kit work for struts?
Old Apr 22, 2009 | 08:26 AM
chibenz's Avatar
02 S500
A very good write up on how to change fuel filter...Its almost similar to w220.
http://www.benzworld.org/forums/r170...lp-please.html
Good Luck
Old Apr 22, 2009 | 03:36 PM
S500 Man's Avatar
what brand fuel filter should i get? is beck/arnley ok?
Old May 7, 2009 | 11:43 PM
Playn's Avatar
How long did it take you to replace the plugs?
