Slow Throttle Response.... Anyone know how to perform a throttle body adaptation?
... any thoughts? Is there a throttle body adaptation procedure that I'm missing perhaps (I would have thought an ECU reset would have solved that but I'm not entirely certain).
OR
You missed the most important part. The issue you described sounds more like an accelerator module issue than a TB. Have you replaced it? Its located at your accelerator pedal. This has to be reprogrammed. Also there is no adaptation for neither components they must be setup using STAR.
ECU only stores and directs info. It doesn't send out configuration information so a reset is pointless if the affected module is reporting incorrect information FYI.
