will lhd steering and suspension components fit a rhd w220 ??
w220 s500
Hello, I bumped the gutter quite hard yesterday on my right hand drive s430 w220 2001 benz, the following parts need replacing - damage was on the front wheel passenger side ( left hand side ) parts required = all control arms - hub support / strut - sway bar - rack and pinion - tie rod end - cross member and lower oil sump ( it has been cracked ) lucky the chassis was undamaged - on the rear wheel same side i require all control arms - i have found some cheap parts on usa ebay off a lhd car of same year and model, but need to know whether any or all of these parts will fit on my rhd car, any help will be much appreciated, cheers ash - sydney australia
Check this:
http://www.detali.ru/cat/oem_mb0.asp?TP=1
These are supposed to be all European parts, so you can compare the parts numbers. My guess: the rear end no problem. The front end is basically mirrored, and so members of the steering assembly may have an impact on the form of sway bars etc.??
