2000 S430 motor mount replacement
Old Nov 17, 2009 | 10:52 PM
vgrigorians's Avatar
2000 MB S430
Hi All;
Does anyone know how to replace the motor mounts on a 2000 S430? dealer is telling me that the motor mounts are collapsed and need to be replaced. Instructions on how to do this is greatly appreciated.
Old Dec 4, 2009 | 02:57 PM
xexpo's Avatar
2000 S430 140k (07/11)
Engine Mount replacement
Here is one for S500. Hope it helps
Old Dec 4, 2009 | 02:58 PM
xexpo's Avatar
Opps sorry, forgot the link
http://www.benzworld.org/forums/w220...ement-diy.html
Old Jan 4, 2025 | 10:23 PM
W220S430KV's Avatar
W220
Great instructions xexpo. I did the job today and the instructions were right on the nose. I appreciate it.
Old Jan 5, 2025 | 12:30 PM
Fried Chicken's Avatar
2005 S500 Designo
It's an awful job. Well done.
You might need to replace the forward flex disk after raising the engine that high
Old Jan 5, 2025 | 01:36 PM
W220S430KV's Avatar
W220
That's on the list for next weekend. I debated doing it all in one fell swoop, but the motor mounts took up the greater portion of the day. It went so well, I figured I would bask in that glory before moving on to the next project.
Old Jan 6, 2025 | 11:40 AM
e350forme's Avatar
fleet
does w220 use that external torx nut under the mount where it connects to the subframe?
i think of V engings , mounts are easier to do than say a straight 5 inline
Old Jan 6, 2025 | 08:28 PM
W220S430KV's Avatar
W220
No. The issue with the W220 is the top bolt on the engine mount, it is tough to get to. But raising the engine first makes it easier.
Old Jan 7, 2025 | 06:54 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
The top bolt doesn't require that weird tool, I can just get to it with a long box wrench... go in from the bottom, remove the exhaust and you have access. Lift is pretty much required here.
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Jan 8, 2025 | 05:57 PM
2005 S500 Designo
I had no issue reaching the top bolt, but getting the new engine mount slotted in correctly that it doesn't turn, while simultaneously tightening the bolt requires some craft.
IMO that's the reason WIS suggests the removal of the engine mount bracket
Old Jan 25, 2025 | 06:44 PM
W220S430KV's Avatar
W220
W220 S430 Flex Disc
Hey Fried Chicken! I still haven't gotten to that flex plate after installing the motor mounts, but I did do the transmission mount. I'm getting an odd sound (like engine pinging) at low speeds, through the first 2 gears and it seems to go away. Could the flex plate be the cause of this sound? I wouldn't think so, but I am a novice. I don't know if the sound was there before doing the motor mounts, but if it was, I never noticed it.
I would appreciate your thoughts.
Thanks!
